It’s been a while that our Discourse has been stuck on the loading screen and I finally found a search term that comes up with some help. However following advice in My forum is stuck on the loading screen I’ve tried to log in with https://service.slaa.network/u/admin-login but the admin emails aren’t being sent to log in! I presume that some deeper problem is there.
I had tried rebuilding the app several times to no avail. I was thinking it might get solved with an update but no.
Following the above advice I removed two plugins that are old and unofficial:
GitHub - procourse/procourse-installer: A Discourse plugin for installing other Discourse plugins.
GitHub - procourse/procourse-static-pages: Allows admins to create static pages in Discourse.
However the rebuild failed completely and so I put the Procourse Installer back (thinking that removing it might have somehow caused a problem since plugins were installed with it) and it’s now back to the the loading screen.
I’m at a bit of a loss as to what to do as I can’t log into safe mode .
I can see that there is an error in the console: ReferenceError: Ember is not defined, but I don’t know how to solve this.
Any ideas?
pfaffman
(Jay Pfaffman)
July 3, 2024, 5:13pm
Remove the procourse installer plugin.
You can append ?safe_mode=no_themes%2Cno_plugins to your url to activate safe mode as an alternative:
https://service.slaa.network/login?safe_mode=no_themes%2Cno_plugins
Though looking in the browser console, it does look like the error is coming from a progress bar component of the procourse installer plugin as Pfaffman suggests.
What errors did you get on the rebuild when you tried removing it?
pfaffman
(Jay Pfaffman)
July 3, 2024, 6:40pm
4
augustinecicc:
removed two plugins
Oops. Sorry, I somehow missed that.
My wild guess is that the Procourse installer left something behind that’s causing a problem, though without the logs it’s just a guess.
You could also have old themes that are causing issues (which are now fixed by the safe-mode URL from Jammy).
JammyDodger:
Thanks very much for this. Sorry for the delay in replying.
When I tried the modified Safe Mode link I was able to login but then was still presented with a loading screen.
I am attaching the ‘log’ from the failed rebuild
discourseinstalllog1.txt (49.7 KB)
Any ideas how to remove the Procourse installer in another way?
I think I see a Zlib::BufError: buffer error (Zlib::BufError) in there.
Could you try adding your DISCOURSE_MAXMIND_ACCOUNT_ID to your app.yml and see if you can rebuild successfully?
I’ve just had this issue when updating a Discourse install…
I believe the cause is because when DISCOURSE_MAXMIND_LICENSE_KEY is specified in the .yml container file without a corresponding DISCOURSE_MAXMIND_ACCOUNT_ID.
@tgxworld ’s pull request adds the use of DISCOURSE_MAXMIND_ACCOUNT_ID in multiple places and explains the need for “Account ID”:
For me the fix was adding DISCOURSE_MAXMIND_ACCOUNT_ID and rebuilding (I rebuilt twice, but this was most likely a temporary issue).
Before I saw your reply I actually had another go at rebuilding after removing the Procourse Installer (after doing a git pull) and it rebuilt fine.
I now have another error, but not fatal, with Discourse Dark Mode Theme that I was using - basically it’s not been updated to Ember 5 it seems from looking at Your site may not work because a theme / component has errors which refers to Preparing for Discourse's upgrade to Ember 5 .
But since it appears that Discourse now has automatic dark mode available Automatic Dark Mode color scheme switching I can delete the Discourse Dark Mode theme!
Thanks for your help but it appears an update has sorted the problem I had.
