Meilleure méthode pour obtenir la configuration SMTP
I’m working on Discourse Doctor.
As part of that, I’m adding a rake task to lib/tasks/emails.rake to test connectivity to the mail server. The way that @j.jaffeux did it in a stand-alone ruby script was
def check_env_var(var)
  if ENV[var].nil? || ENV[var].empty?
    error("#{var} is blank, edit containers/app.yml variables")
check_env_var("DISCOURSE_SMTP_ADDRESS")
check_env_var("DISCOURSE_SMTP_PORT")
check_env_var("DISCOURSE_SMTP_USER_NAME")
check_env_var("DISCOURSE_SMTP_PASSWORD")
Net::SMTP.start(ENV["DISCOURSE_SMTP_ADDRESS"], ENV["DISCOURSE_SMTP_PORT"])
             .auth_login(ENV["DISCOURSE_SMTP_USER_NAME"], ENV["DISCOURSE_SMTP_PASSWORD"])
That’s working, but is there a more Railsy/straightforward way to get those SMTP values from Rails rather than ENV?
I’m also not sure that the rake task needs to mention app.yml, as I think that now discourse-setup does a pretty good job of checking that up front, so I think that I can just remove the check_env_var part.
Nice to see this getting some :heart_with_arrow:, the doctor :woman_health_worker: is in!
Is this the right place?
Discourse::Application.config.action_mailer.smtp_settings
Looks like it! It’s obvious when you know. :slight_smile:
Many thanks!
