Hi, I follow this Multisite configuration with Docker to multisite, now I want to recover to one site, what should I do except restore the app.yml file?
I really don’t understand what you’re trying to achieve here but if you want to move one site out of the multisite setup, you can do that by downloading a backup from the multisite and restoring it on the standalone site. You may have to do some remapping based on how this standalone is set up.
I just want to keep the first site, delete the second site.
Yes, Simplest approach is to take a backup of the first site, shut down the two containers (web_only & data) which you may have used while setting up multisite, set up a new site through ./discourse-setup and then restore your backup. A more advanced solution may include removing the second site config from the yml files, getting into the data container to drop the second database, removing the second site assets from the shared folder etc.
Thanks! I will try the first method.
Hi, I follow your seconde method. I removed the database of the second site, and restored the app.yml config file. But I don’t know how to remove the second site assets from the shared folder, could you help me?
When I upgrade discourse, I got a empty page in plugin page, and error in console:
Uncaught TypeError: Cannot read property 'extend' of undefined
at _discourse-rss-poster-422da9e50d576ad45cb7287315e7a35550af3708eb68422bee05813edc01521d.js:188
at t.module.exports.u.<computed> (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:74640)
at t.module.exports.u.<computed> (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:74470)
at require (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:74637)
at t.customResolve (_application-572c27eef10b724b244ce26553c6fe92b75f44172387b25ef144f338da4faa1e.js:1015)
at t.resolveRoute (_application-572c27eef10b724b244ce26553c6fe92b75f44172387b25ef144f338da4faa1e.js:1051)
at t.e [as resolveRoute] (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:43433)
at t.n.resolve (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:46378)
at _ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:12420
at e.t.resolve (_ember_jquery-1ed3f3559e6f967733b4088aa729ff7039dff2c09c5a5f787a214b016f58aabc.js:11959)
I think it’s due to the second site but I don’t know how to fix it. Thanks!
Could you pls help me? @sam
You’ll have to share your app.yml file redacting the passwords. I would blame this on some omission or error in your app.yml file that is causing this.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
# - "templates/web.ssl.template.yml"
# - "templates/web.letsencrypt.ssl.template.yml"
- "templates/web.socketed.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
# - "80:80" # http
# - "443:443" # https
params:
db_shared_buffers: "128MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 2
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: at4am.io
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'a@gmail.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.office365.com
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: a@outlook.com
DISCOURSE_SMTP_PASSWORD: "a"
DISCOURSE_SMTP_AUTHENTICATION: login
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: a@gmail.com
## The CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
#DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
- git clone https://github.com/livc/discourse-rss-poster
#- git clone https://github.com/paviliondev/discourse-ratings
- git clone https://github.com/discourse/discourse-data-explorer
- git clone https://github.com/discourse/discourse-solved
run:
It’s my app.yml, thanks for your help.
Looking at your previous error and the app.yml, most probably it’s the rss plugin fork that you’re using. Something may be broken in it that’s probably causing the issue. Can you try rebuilding after disabling the plugin?
If I comment this plugin the plugin page is work. But before I upgrade discourse to latest version, the plugin work and has no problem.
So I am not sure it’s due to the upgrade of discourse or the multisite.
Especially, I found
https://meta.discourse.org/t/discourse-subscriptions/140818/77?u=livc
get same error on multisite.
This plugin is very important for my site and I have no idea now. ![]()
If you made that plugin, try fixing it. If someone built it for you, try contacting them to get it fixed
