The current resizing syntax accepts a size argument in the form of |WxH[, perc%], where the WxH part appears always madatory. However, folks (read: I) occasionally want to only specify either the width/height (maintaining ratio, of course) or the percentage only. Will it be a good idea to relax these constraints?
Here’s a list of possible extensions, meant to duplicate the functionalities of MediaWiki’s image sizes:
WxHextensions-
|W(e.g.![foo|220]) can interpreted as a request to only add awidthattribute to theimgelement generated. -
|xH(e.g.![foo|x200]) can interpreted as a request to only add aheightattribute to theimgelement generated. -
brainless scalng:
|MWxH(e.g.![foo|M200x200]) sets the maximum dimension of the image to 200x200px, but does not distort it when scaling. (Inlinestyle?)- usage note: on Wikipedia this is most useful for fitting images into a box of a given size, centered and padded automatically. There aren’t many fixed-size boxes in discourse, so it might be more useful making it an
imgwith margin/padding added to reach the target size. Sounds a bit too complicated though.
- Most modern browsers does a proportional scaling with only one dimension given. Something along the lines of
img { width: auto; height: auto }may be required for older stuff. - Only specifying one dimension obviously can cause abrupt layout changes as the image gets loaded. To avoid it, maybe auto-rewrite the expression into the full
WxHform on save?
- percent-only sizing (
![|50%])- This is the same as
[|WxH,perc%], whereWxHare the real dimensions of the image. - Applying percentages to
img's dimension attributes is awful, so this must get rewritten into the fullWxHform.
Security considerations
- Expanding the expression into a usual
WxHform involves opening an image and reading its dimensions. If there’re some vulnerbilities in your image-handling libraries, you may be doomed. - Having the server fetch a remote image is a good way to expose the server IP, which might be hidden behind some sort of an anti-DDoS CDN. Maybe only rewrite the sizes on local imgs?
- Discourse already fetches remote images to generate a metadata section.
