What is “[zh_CN.solved.solution_summary.other
count=undefined]” in the picture? How to remove it?
I think this is added by a theme. Which theme do you use?
Thank you. The theme I use is FKB Pro theme.GitHub - VaperinaDEV/fkb-pro-theme: FKB Pro is a highly modified, detailed, professional social theme, but still user-friendly.
That theme has a fkb panel show solutions setting, which you can disable if you don’t use the solved plugin.
Thanks >.<
