Eliminar perfiles de 'Our Admins'
¿Podría alguien por favor aconsejarme cómo eliminar/ocultar los perfiles de ‘Nuestros administradores’ que aparecen en la página ‘Acerca de’, por favor?
https://businesscomputingworld.co.uk/about
Muy agradecido, y gracias por su tiempo.
you can do it with CSS (add to admin > customize > themes > edit CSS/HTML > common ), but the information will still be available if someone looks at the page source
.about.admins {
  display: none
If you want to completely remove it you’ll have to override the handlebars template (add this to admin > customize > themes > edit CSS/HTML > header). This is our default template for that page with the admin section removed.
<script type='text/x-handlebars' data-template-name='about'>
{{#d-section pageClass="about"}}
  <div class='container'>
    <div class='contents clearfix body-page'>
      <ul class="nav-pills">
        <li class="nav-item-about">{{#link-to 'about' class="active"}}{{i18n 'about.simple_title'}}{{/link-to}}</li>
        {{#if faqOverriden}}
          <li class="nav-item-guidelines">{{#link-to 'guidelines'}}{{i18n 'guidelines'}}{{/link-to}}</li>
          <li class="nav-item-faq">{{#link-to 'faq'}}{{i18n 'faq'}}{{/link-to}}</li>
        {{else}}
        {{/if}}
        <li class="nav-item-tos">{{#link-to 'tos'}}{{i18n 'tos'}}{{/link-to}}</li>
        <li class="nav-item-privacy">{{#link-to 'privacy'}}{{i18n 'privacy'}}{{/link-to}}</li>
      </ul>
      <section class='about description'>
        <h2>{{i18n 'about.title' title=model.title}}</h2>
        <p>{{model.description}}</p>
      </section>
      {{plugin-outlet name="about-after-admins"
                    connectorTagName='section'
                    args=(hash model=model)}}
      {{#if model.moderators}}
        <section class='about moderators'>
          <h3>{{d-icon "users"}} {{i18n 'about.our_moderators'}}</h3>
          <div class='users'>
            {{#each model.moderators as |m|}}
              {{user-info user=m}}
            {{/each}}
          </div>
          <div class='clearfix'></div>
        </section>
      {{/if}}
      {{plugin-outlet name="about-after-moderators"
      <section class='about stats'>
        <h3>{{d-icon "bar-chart"}}  {{i18n 'about.stats'}}</h3>
        <table class='table'>
          <tr>
            <th>&nbsp;</th>
            <th>{{i18n 'about.stat.all_time'}}</th>
            <th>{{i18n 'about.stat.last_7_days'}}</th>
            <th>{{i18n 'about.stat.last_30_days'}}</th>
          </tr>
          <tr>
            <td class='title'>{{i18n 'about.topic_count'}}</td>
            <td>{{number model.stats.topic_count}}</td>
            <td>{{number model.stats.topics_7_days}}</td>
            <td>{{number model.stats.topics_30_days}}</td>
          </tr>
          <tr>
            <td>{{i18n 'about.post_count'}}</td>
            <td>{{number model.stats.post_count}}</td>
            <td>{{number model.stats.posts_7_days}}</td>
            <td>{{number model.stats.posts_30_days}}</td>
          </tr>
          <tr>
            <td>{{i18n 'about.user_count'}}</td>
            <td>{{number model.stats.user_count}}</td>
            <td>{{number model.stats.users_7_days}}</td>
            <td>{{number model.stats.users_30_days}}</td>
          </tr>
          <tr>
            <td>{{i18n 'about.active_user_count'}}</td>
            <td>&mdash;</td>
            <td>{{number model.stats.active_users_7_days}}</td>
            <td>{{number model.stats.active_users_30_days}}</td>
          </tr>
          <tr>
            <td>{{i18n 'about.like_count'}}</td>
            <td>{{number model.stats.like_count}}</td>
            <td>{{number model.stats.likes_7_days}}</td>
            <td>{{number model.stats.likes_30_days}}</td>
          </tr>
        </table>
      </section>
      {{#if contactInfo}}
        <section class='about contact'>
            <h3>{{d-icon "far-envelope"}} {{i18n 'about.contact'}}</h3>
            <p>{{{contactInfo}}}</p>
        </section>
      {{/if}}
    </div>
  </div>
{{/d-section}}
</script>
