Remove quote of the solution if solved quote length is set to zero
A discussion was started by Kovah about removing the quote of the solution when the “solved quote length” is set to zero, instead displaying only a link to the solved post. Clapmyhands initially offered to work on this feature but later had to drop it due to personal reasons. Xrav3nz then created a PR for this feature, which was later merged by sam. The PR included screenshots demonstrating the feature, where setting “solved_quote_length” to 0 removes the embedded quote.
I would prefer to only display a link to the solved post instead of embedding the whole content. Therefore, setting the option “solved quote length” to 0 (zero) should disable the embedded quote and only display the “Solved by xyz in post 23”.
I thought the corresponding line is this one, tried to implement it on my own but but the box disappeared completely.
3개의 좋아요
Sure, this is fine with me, pr-welcome
3개의 좋아요
heya, :slight_smile: if nobody is working on this yet, I think I can try working on this.
but if anyone have a pr ready then feel free to stop me.
3개의 좋아요
@clapmyhands Any news about that?
no unfortunately I’ve been swamped with life stuff and haven’t had the chance / might not be able to continue contributing. :sweat_smile:
If anybody want to take up the job, feel free.
PR for this feature. Open to suggestions!
https://github.com/discourse/discourse-solved/pull/65
Screenshots
solved_quote_length := 0
solved_quote_length := 10
6개의 좋아요
Merged in now, big thanks @xrav3nz :pizza:
4개의 좋아요
