Remove `spork-rails` from Discourse
As part of our efforts to upgrade to Rails 5, we’ll need to deprecate spork-rails which currently locks Rails to < 5. However, Rails 5 support for the gem is probably never going to land as the last commit made to the gem is way back in 2013. The main thing using spork in our code base is autospec so we’ll need to figure out an alternative for it.
Going to tag this pr-welcome in the meantime.
Not strictly the case, it is optional, have not used spork personally for years, can be nuked with impunity
Since there’s action cables integrated in Rails 5 to add support for WebSockets, can you confirm Discourse won’t use it :slight_smile:
We will not add the action cable dependency and have zero plans of using it
Hello,
This PR should remove all traces of Spork.
https://github.com/discourse/discourse/pull/5035
Thank you @nbianca, PR has been merged with tests all :white_check_mark:
