In each of these cases we’d set up a special category, open it up for voting and discussion during a limited voting period, and then close it again when we’re done.
So… if such wider usage of this plugin is generally likely to happen, perhaps it should be called “topic voting” instead of “feature voting”.
I also wonder if it wouldn’t make sense to provide category admin settings for the number of votes and super votes available per user in the category.
This is now complete, the plugin is called “Discourse Voting”, repo was moved all localization was changed to reflect and all source code and references were changed to reflect.
