Hello,
I have the following hook in my discourse yml container config:
hooks:
after_code:
- replace:
global: true
filename: /var/www/discourse/app/controllers/users_controller.rb
from: /^.*StaffActionLogger\.new\(current_user\)\.log_check_email.*$/
to: ""
That’s a work-around for the issue explained here:
https://meta.discourse.org/t/intense-api-use-floods-staff-log/48214/5
If I do an update with docker_manager and the configuartion is a different one afterwords, that means a configuration without the replace hook, that I would consider this to be a bug. ![]()
