ReplyGif
@cpradio Hey buddy - thanks for all your work with the animated gif plugin. Things seem to be operational, but I get the following error when I’m trying to use the tag search.
Uncaught TypeError: c.template is not a function
at _application-84dd57853abdabbc6192544517edf1800652f49b885ebcbbca8df6a1ca441625.js:15256
at j (_application-84dd57853abdabbc6192544517edf1800652f49b885ebcbbca8df6a1ca441625.js:15371)
at HTMLInputElement.<anonymous> (_application-84dd57853abdabbc6192544517edf1800652f49b885ebcbbca8df6a1ca441625.js:15431)
at HTMLInputElement.dispatch (_ember_jquery-8ef4e572f0bf9485e6ef9a35f088729735f82434cf495fbcd5acedefbcddb363.js:5251)
at HTMLInputElement.v.handle (_ember_jquery-8ef4e572f0bf9485e6ef9a35f088729735f82434cf495fbcd5acedefbcddb363.js:5058)
Do you have some ideas to help troubleshoot? Hope you’re staying safe right now!
לייק 1
This is now fixed, update via the admin tool and it will work.
לייק 1
As per instruction this is setup for you.
Details: The discourse container has nginx running inside of it and configured. Nginx is the web server has capability to do reverse proxy. The instructions document using a template ( templates/web.replygif.template.yml), which carries the reverse proxy snippet that discourse’s automation will use to reconfigure nginx settings. Once you rebuild the server, the automation will be applied and you get the reverse proxy.
I finally figured out what to do with:
wget https://raw.githubusercontent.com/cpradio/discourse-plugin-replygif/master/web.replygif.template.yml -O /var/discourse/templates/web.replygif.template.yml
that was my hangup.
Thanks for the help @Joaquin_Menchacha & @cpradio
2 לייקים
Hello I’m using giphy in my forum, but i just have a little issue, the icon doesn’t appear in the window.
לייק 1
If you are using Giphy, then this isn’t the right topic. This is for ReplyGif. Seems whoever forked it for giphy hasn’t updated it in a few years and the font-awesome reference they have is no longer supported.
4 לייקים
Oh i’m sorry, thank you. :slight_smile:
לייק 1
@PaulinaMX, I have updated the giphy plugin to fix it. You will need to update your app.yml to point to the new repository location until the owner takes my changes.
6 לייקים
Thanks, i’m going to try this.
לייק 1
@cpradio Thank you :heart: It’s working now.
4 לייקים
I just set this up, but I only see “Loading… Loading…” in the modal. I thought I had done something wrong with setting up the reverse proxy, but I wen’t to replygif.net and it looks like the api isn’t working their either.
Just wanted to do a sanity check it see if it was just me or if replygif.net is down?
3 לייקים
Not the same thing, but there is a theme component in the same area using Giphy that may be useful for you: Discourse Gifs component
2 לייקים
oh, I had installed the giphy plugin, but the theme component is even better. I didn’t know that was a thing, thanks!
2 לייקים
Is it always working with last version of Discourse ?
If yes i will test it. i can translate it to french too if needed.
לייק 1
Maybe I don’t understand this, maybe see Notice: testing Discourse Reactions here on meta for 1 week! - #9 by awesomerobot
לייק 1
dont work :(:(:(:(:frowning:
3 לייקים
Thanks for the report, moved to broken.
As a heads up, this plugin main functionality is also covered by the Discourse Gifs theme-component.
3 לייקים
2 posts were merged into an existing topic: Watched Words to serve as shortcut command to insert links
