Request: Synchronize green indicator for unread private messages when the topic is open
Users are reporting an inconsistency where the green unread private message indicator on avatars does not clear immediately when a new message is viewed within an open topic. Lutz describes the issue: the counter increments upon receiving a message, but remains visible even after the user sees the message in the open topic, only clearing after navigating away. erlend_sh confirms this is a frequent occurrence, arguing that the indicator should clear as soon as the message is opened rather than waiting for a specific read-timing trigger. sam requests a clear reproduction path, clarifying that the system is designed to clear the green dot only after the message is marked as read based on timing, not merely on opening. erlend_sh questions the UX benefit of this delay, a sentiment echoed by zogstrip, who notes the behavior feels inconsistent despite PMs being important. fefrei suggests the issue may be related to a known bug regarding notification counts not decreasing live and adds that scrolling through the post sometimes fails to clear the indicator, implying the issue is more complex than simple read-timing logic.
It is somewhat complicated to explain.
Let’s say you have a private conversation with a member and the appropriate topic /t/[topic-name]/[numbers] is open. Now the member will send you a new message in this topic. The green indicator for new private messages (on the Avatar) goes to (1). You directly see the message in the topic, since it is already open. Now you switch to another topic and the green (1) is still there.
It would be nice if this was synchronized.
إعجابَين (2)
I think this worked at some point, and might be related to this:
3 إعجابات
I’m experiencing this all the time. I’ll making a recording next time I receive a PM (feel free to send me a test PM; too lazy to do that myself with a test user during the weekend!)
In short, the notification is still there when I open a message, when really it should be cleared as soon as you’ve opened the message.
3 إعجابات
I need a clear and exact repro, this is something I would like fixed
Keep in mind though, green is cleared when you read the message, not when you open it. I used the post timing stuff to trigger the clearing
إعجاب واحد (1)
That might be all it is then. I think I’m just used to it being cleared immediately upon open. Couldn’t we do that instead?
I don’t really see the UX benefit of waiting for the post-read timing to trigger it.
Probably because PM are more important than regular posts?
But I agree, it feels inconsistent.
I don’t have a consistent way to repro it, but it happens quite often to me. There’s definitely more to it then requiring to actually read the post, when it happens to me scrolling through the post doesn’t help.
