Is there a way to reset the password to a known state using the command line interface. An added complication is that the email functionality is not working which prevents a straight password reset via email.
What did you do to break your email?
You can check Troubleshooting Outgoing Email and Troubleshoot email on a new Discourse install.
To reset the password
cd /var/discourse
./launcher enter app
rake admin:create
Thanks. I never used Ruby/Rails before and just discovered the power of Rake -T and Rake -W
Thanks!
