비밀번호 재설정 링크 오류
안녕하세요!
첫 번째 discourse 포럼을 테스트하던 중 비밀번호 재설정 링크에서 문제가 발생했는데, 다른 게시글에서 해결책을 찾지 못했습니다.
이 오류에서 수집한 정보를 첨부합니다.
오류:
Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We'll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site's feedback category.
domain.example/logs의 정보
Message (4 copies reported)
ActionView::Template::Error (The asset "ember_jquery.js" is not present in the asset pipeline.
app/helpers/application_helper.rb:95:in `script_asset_path'
app/helpers/application_helper.rb:146:in `block in preload_script'
app/helpers/application_helper.rb:145:in `map'
app/helpers/application_helper.rb:145:in `preload_script'
app/views/users/password_reset.html.erb:20
app/views/users/password_reset.html.erb:18
app/controllers/users_controller.rb:830:in `block (2 levels) in password_reset_show'
app/controllers/users_controller.rb:820:in `password_reset_show'
app/controllers/application_controller.rb:415:in `block in with_resolved_locale'
app/controllers/application_controller.rb:415:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:368:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:202:in `call'
Backtrace
sprockets-rails (3.4.2) lib/sprockets/rails/helper.rb:84:in `compute_asset_path'
actionview (7.0.3) lib/action_view/helpers/asset_url_helper.rb:203:in `asset_path'
actionview (7.0.3) lib/action_view/helpers/capture_helper.rb:45:in `block in capture'
actionview (7.0.3) lib/action_view/helpers/capture_helper.rb:209:in `with_output_buffer'
actionview (7.0.3) lib/action_view/helpers/capture_helper.rb:45:in `capture'
이메일 텍스트 설정:
정말 감사합니다!!!
Francisco.-
이 문제는 최신 버전에서 수정된 것으로 보입니다. 업데이트를 시도해 주시겠습니까?
2개의 좋아요
며칠 전에 DigitalOcean에서 설치했습니다. 최신 버전으로 업데이트하려면 어떻게 해야 하나요?
이 작업은 /admin/upgrade 페이지에서 수행할 수 있습니다. :+1: 다만 자체 호스팅(self-hosted)을 사용 중이라면 이 주제인 Discourse와 Docker 이미지를 최신 버전으로 수동 업데이트하는 방법?도 확인해 보시기 바랍니다.
그 게시글의 두 번째 단계만 수행했는데 해결되었습니다. 감사합니다!
2개의 좋아요
