OPGELOST - Afbeeldingsuploadfout met Discourse Antivirus
JackHouzi reported an image upload error in Discourse after updating to the latest version, encountering the error "undefined method map' for nil:NilClass". After sharing logs and a screenshot, [Falco](/t/-/169604/2) requested full logs, which [JackHouzi](/t/-/169604/3) provided, pointing to the discourse-antivirus` plugin as the source of the issue. sam advised that the plugin is complex and requires custom infrastructure, recommending its removal unless the user is comfortable debugging it. JackHouzi confirmed that disabling the plugin resolved the issue and thanked the community for their help.
Hey hi everyone,
Since 4 days now, i’ve updated Discourse and all its modules to the lastest version, but each time me or a member try to upload an image, we get this error : “undefined method `map’ for nil:NilClass”
Can’t find any infos on it, as it seems it’s a generic errors and it can be produced not only with the image uploader.
Does anyone can help here ? Any advice is welcomed. thanks a lot :slight_smile:
Can you please paste full logs with backtraces from /logs?
Hi @Falco
Thx a lot for your quick answer.
Here is my copy/paste :
    Job exception: JavaScript was terminated (either by timeout or explicitly)
27 Jun 3:47 pm
8
Job exception: Connection timed out
30 Jun 9:05 am
Mime::Type::InvalidMimeType ("%{#context['com.opensymphony.xwork2.dispatcher.httpservletresponse'].addheader('mangozda3'" is not a valid MIME type) /var/www/discourse/vendor/bundle/ruby/2.6.0/gems/act
12 Jul 8:59 pm
Job exception: execution expired
28 Aug 8:07 am
6
ArgumentError (wrong number of arguments (given 0, expected 1..2)) app/models/user_stat.rb:157:in `calc_topic_reply_count!' lib/promotion.rb:94:in `tl2_met?' lib/promotion.rb:36:in `review_tl1' lib/pr
5 Sep 12:07 pm
NoMethodError (undefined method `map' for nil:NilClass) app/controllers/application_controller.rb:340:in `block in with_resolved_locale' app/controllers/application_controller.rb:340:in `with_resolved
23 Sep 6:37 pm
Job exception: Connection reset by peer
3 Oct 9:35 am
NoMethodError (undefined method `map' for nil:NilClass) app/controllers/application_controller.rb:354:in `block in with_resolved_locale' app/controllers/application_controller.rb:354:in `with_resolved
10 Oct 6:31 pm
4
Mime::Type::InvalidMimeType ("\\*\\/\\*" is not a valid MIME type) lib/middleware/omniauth_bypass_middleware.rb:68:in `call' lib/content_security_policy/middleware.rb:12:in `call' lib/middleware/anony
11 Oct 5:14 am
12
18 Oct 10:05 pm
15
Job exception: undefined method `map' for nil:NilClass
1:12 pm
356
1:47 pm
I’ll put a screenshot for a better comprehension :
And once i clicked on the last line to open it :
Message (357 copies reported)
Job exception: undefined method `map’ for nil:NilClass
Backtrace
/usr/local/lib/ruby/2.6.0/resolv.rb:1248:in `initialize'
/var/www/discourse/plugins/discourse-antivirus/gems/2.6.6/gems/dns-sd-0.1.3/lib/dns-sd/service_instance.rb:54:in `new'
/var/www/discourse/plugins/discourse-antivirus/gems/2.6.6/gems/dns-sd-0.1.3/lib/dns-sd/service_instance.rb:54:in `initialize'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/clamav_services_pool.rb:31:in `new'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/clamav_services_pool.rb:31:in `service_instance'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/clamav_services_pool.rb:20:in `all_tcp_sockets'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/clamav.rb:24:in `update_versions'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/clamav.rb:20:in `versions'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/background_scan.rb:28:in `current_database_version'
/var/www/discourse/plugins/discourse-antivirus/lib/discourse_antivirus/background_scan.rb:52:in `scan_batch'
Hope i’ve shared it right !
discourse-antivirus is a very complex plugin that requires a lot of custom infrastructure and setup. I recommend you remove it unless you are comfortable debugging this kind of stuff yourself.
Indeed ! desactivating it did the job !
I feel a bit stupid… but Thanks a lot for your help :slight_smile:
