Hi all,
This seems basic but I can’t figure out how to do it …
Is there a way to revert all email templates that are sent out to the default settings? A fellow admin has messed with them and they’re all pretty ugly now ![]()
Thanks!
James
Hi all,
Thanks!
James
If you go to Admin/Customize/Email Templates and click through the templates list, there should be a Revert Changes button underneath each template that has been edited. Clicking that should restore the template to its default version.
Ahh that’s the tip - I didn’t realise it only appeared on those that had been changed.
Thanks heaps @simon!
