Restrict access for specific user
Is it possible to restrict access of a specific user?
My use case is that I want to create a “product feedback bot”-user, that will post in a specific category once people fill in a form embedded in our product.
The API key of this bot would most likely be visible to a determined (trusted) product user. I’d like to restrict the use to posting in a specific category.
Is there a way to strip them of any trust level? I can then grant them posting rights to a specific category
You can lock the user to TL0.
That makes sense, at least prevents some of the privileges, but then they can still post in e.g. Uncategorised.
I want this 1 user, to only be able to post in this 1 category, but I feel this usecase isn’t supported yet.
You will have to put the user in a group and add that group as read only to every category but the one they’re allowed to post into.
Ah, they use the most restrictive of the permissions granted? I thought they’d be additive.
So a category with Create / Reply / See doe “everyone” and See for e.g. “bot-group” wouldn’t allow the bot to post?
That could work!
That’s a good point. I’m not actually 100% sure.
EDIT: just tested, and they’re indeed additive. So I’m afraid your use case isn’t supported at this time.
