Is there any way to retrieve those AI summaries via API call? We would like to display those AI summaries automatically in our wordpress blog on product pages.
Anything that displays in the ux you can get with the API. You can probably just add .json
to the url, but see Reverse engineer the Discourse API
Use the following endpoint:
https://SITE/discourse-ai/summarization/t/TOPIC_ID.json
Eg:
curl https://meta.discourse.org/discourse-ai/summarization/t/325562.json
Be sure not to include the stream
parameter. The stream
parameter will cause the message bus to deliver new summaries, which is a more complex protocol.
Also, be sure to use an API key for a user in a group that is able to generate summaries.
