We have umlauts enabled in usernames, which works fine in markdown, but not in the new composer:
Thanks for the report. We’ll take a look!
I was able to repro after configuring the following settings:
- configuring these settings to allow some unicode characters in usernames
unicode_usernames
allowed_unicode_username_characters
(e.g.[äöüßÄÖÜẞ]
- create a user using one of those chars in their username
- try to mention them in a post using the new rich text editor
We should double check that mentions for group names w/ unicode characters work too when we fix this.
Related: Unicode usernames and group names
Just to remain that so called swedish o, å and Å, misses from that list. And yet it can be just an example, and å/Å is accepted — never tested (mostly because all Finns have learnt not to use those letters)
Thank you for reporting, unicode support has been added with this change:
This topic was automatically closed after 3 days. New replies are no longer allowed.
