Rspec failing to load when using the official beginners guide
סיכום מבוסס בינה מלאכותית
Rspec Failing to Load
User dmitry_fedyuk is experiencing an issue with Rspec failing to load while following the Beginners Guide to Install Discourse on Ubuntu for Development. Specifically, the bundle exec rake autospec step is failing, resulting in a LoadError.
The error message indicates that Rspec is unable to load the support/source file. dmitry_fedyuk is using the latest stock version of Ubuntu Desktop (16.04.3 LTS) and has not installed any extra packages beyond what is required by the guide. A similar issue has been reported in another topic: meta.discourse.org/t/topic/69830.
@techAPJ
«Beginners Guide to Install Discourse on Ubuntu for Development».
I use the latest stock version of Ubuntu Desktop (16.04.3 LTS) which is unmodified, without any extra packages previously installed apart from the guide’s previous steps packages .
The bundle exec rake autospec guide’s step fails:
~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-support-3.6.0/lib/rspec/support.rb:28:in `require_relative': cannot load such file -- ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-support-3.6.0/lib/rspec/support/source (LoadError)
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-support-3.6.0/lib/rspec/support.rb:28:in `block in <module:Support>'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-support-3.6.0/lib/rspec/support.rb:19:in `block in define_optimized_require_for_rspec'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/world.rb:135:in `source_from_file'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/snippet_extractor.rb:18:in `source_from_file'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/snippet_extractor.rb:30:in `extract_expression_lines_at'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:218:in `read_failed_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:163:in `failure_slash_error_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:150:in `block in failure_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:149:in `tap'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:149:in `failure_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:34:in `colorized_message_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:240:in `formatted_message_and_backtrace'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:86:in `fully_formatted_lines'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/exception_presenter.rb:78:in `fully_formatted'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/notifications.rb:200:in `fully_formatted'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/notifications.rb:114:in `block in fully_formatted_failed_examples'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/notifications.rb:113:in `each'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/notifications.rb:113:in `each_with_index'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/notifications.rb:113:in `fully_formatted_failed_examples'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/formatters/base_text_formatter.rb:32:in `dump_failures'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:206:in `block in notify'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:205:in `each'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:205:in `notify'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:175:in `block in finish'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:191:in `close_after'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:171:in `finish'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:81:in `ensure in report'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/reporter.rb:81:in `report'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/runner.rb:112:in `run_specs'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/runner.rb:87:in `run'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/runner.rb:71:in `run'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/lib/rspec/core/runner.rb:45:in `invoke'
	from ~/.rbenv/versions/2.4.2/lib/ruby/gems/2.4.0/gems/rspec-core-3.6.0/exe/rspec:4:in `<top (required)>'
	from bin/rspec:16:in `load'
	from bin/rspec:16:in `<main>'
A similar problem: meta.discourse.org/t/topic/69830
