I can’t enter links. I only see the black overlay, no modal though. Anyone having the same issues as me ?
לייק 1
It works fine with en locale
Yes that will be a problem for all RTL layouts.
The problem is that the left position of the insert-link modal is hard-coded into the html. Anytime left or right positioning is set with inline styles it will break for rtl layouts unless a check is made in the code to see if the current layout is rtl and the left/right values are flipped.
Sure, Can you give me the element that gets the inline property ? I’ll change it with Jquery from admin as a temporary solution
it is .rtl .d-editor .d-editor-modal.insert-link[style]
You can get in on the screen, but not centered, with this as custom css:
.rtl .d-editor .d-editor-modal.insert-link[style] {
left: auto !important;
right: 50px;
2 לייקים
Fair enough. It works ! Thanks
