Supporto Ruby 3 relativo alla gemma mocha
Ho un altro argomento da trattare per supportare Ruby 3.
Passaggi per riprodurre
$ bundle exec rspec ./spec/lib/backup_restore/database_restorer_multisite_spec.rb:15
Risultato effettivo con Ruby 3.0.2
$ ruby -v
ruby 3.0.2p107 (2021-07-07 revision 0db68f0233) [x86_64-linux]
Run options: include {:locations=>{"./spec/lib/backup_restore/database_restorer_multisite_spec.rb"=>[15]}}
Randomized with seed 43732
F
Failures:
  1) BackupRestore::DatabaseRestorer#restore database connection reconnects to the correct database
     Failure/Error:
       log Discourse::Utils.execute_command(
           "SKIP_POST_DEPLOYMENT_MIGRATIONS" => "0",
           "SKIP_OPTIMIZE_ICONS" => "1",
           "DISABLE_TRANSLATION_OVERRIDES" => "1"
         "rake", "db:migrate",
         failure_message: "Failed to migrate database.",
         chdir: Rails.root
     Mocha::ExpectationError:
       unexpected invocation: Discourse::Utils.execute_command({"SKIP_POST_DEPLOYMENT_MIGRATIONS" => "0", "SKIP_OPTIMIZE_ICONS" => "1", "DISABLE_TRANSLATION_OVERRIDES" => "1"}, "rake", "db:migrate", {:failure_message => "Failed to migrate database.", :chdir => #<Pathname:0xd548>})
       unsatisfied expectations:
       - expected exactly once, invoked never: Discourse::Utils.execute_command()
       - expected exactly once, invoked once: BackupRestore.move_tables_between_schemas("public", "backup")
       - expected at least once, invoked 77 times: Migration::BaseDropper.create_readonly_function(any_parameters)
       - expected exactly once, invoked once: #<Mock:psql status>.exitstatus(any_parameters)
       - expected exactly once, invoked once: Process.last_status(any_parameters)
       - expected exactly twice, invoked twice: #<Mock:psql>.readline(any_parameters)
       - expected exactly once, invoked once: IO.popen(any_parameters)
     # ./lib/backup_restore/database_restorer.rb:138:in `migrate_database'
     # ./lib/backup_restore/database_restorer.rb:27:in `restore'
     # ./spec/lib/backup_restore/shared_context_for_backup_restore.rb:59:in `execute_stubbed_restore'
     # ./spec/lib/backup_restore/database_restorer_multisite_spec.rb:17:in `block (4 levels) in <top (required)>'
     # ./spec/rails_helper.rb:279:in `block (2 levels) in <top (required)>'
Finished in 0.28437 seconds (files took 2.37 seconds to load)
1 example, 1 failure
Failed examples:
rspec ./spec/lib/backup_restore/database_restorer_multisite_spec.rb:15 # BackupRestore::DatabaseRestorer#restore database connection reconnects to the correct database
Risultato effettivo con Ruby 2.7.4
$ ruby -v
ruby 2.7.4p191 (2021-07-07 revision a21a3b7d23) [x86_64-linux]
Randomized with seed 37771
Finished in 0.63589 seconds (files took 2.63 seconds to load)
1 example, 0 failures
Cosa ho scoperto finora
In realtà, questo è un altro caso che richiede il supporto degli argomenti chiave di Ruby 3.
  • Esegui con Ruby 2.7.4 abilitando -w e trova warning: Using the last argument as keyword parameters is deprecated
$ bundle exec rspec -w ./spec/lib/backup_restore/database_restorer_multisite_spec.rb:15 2>&1 | grep keyword
/home/yahonda/.rbenv/versions/2.7.4/lib/ruby/gems/2.7.0/gems/mocha-1.13.0/lib/mocha/parameters_matcher.rb:13: warning: Using the last argument as keyword parameters is deprecated; maybe ** should be added to the call
  • Ecco una rapida soluzione sporca con codice di debug di stampa.
$ git diff 191823e8696881ab8c72948165834eca18315cb3...8141f2f0eca4bedcf59e34f31dd9ca35e39c2a25
diff --git a/lib/mocha/parameters_matcher.rb b/lib/mocha/parameters_matcher.rb
index 2b6ed84..26c4a25 100644
--- a/lib/mocha/parameters_matcher.rb
+++ b/lib/mocha/parameters_matcher.rb
@@ -10,7 +10,11 @@ module Mocha
     def match?(actual_parameters = [])
       if @matching_block
-        @matching_block.call(*actual_parameters)
+        p actual_parameters
+        if actual_parameters.last.is_a? Hash
+          kwargs = actual_parameters.pop
+        end
+        @matching_block.call(*actual_parameters, **kwargs)
       else
         parameters_match?(actual_parameters)
Risultato con il codice mocha modificato
Randomized with seed 27573
[{"SKIP_POST_DEPLOYMENT_MIGRATIONS"=>"0", "SKIP_OPTIMIZE_ICONS"=>"1", "DISABLE_TRANSLATION_OVERRIDES"=>"1"}, "rake", "db:migrate", {:failure_message=>"Failed to migrate database.", :chdir=>#<Pathname:/home/yahonda/src/github.com/discourse/discourse>}]
Finished in 0.40263 seconds (files took 2.88 seconds to load)
Potrebbe essere necessario creare un caso minimo per mocha. Sarei grato se qualcuno avesse suggerimenti.
Sì, sembra una correzione per Mocha. Hai aperto un rapporto di bug su GitHub per questo?
Non ancora. Ci darò un’occhiata più approfondita questa settimana.
Ho trovato un problema simile giĂ  segnalato e viene spiegata una soluzione temporanea
Usa kwargs invece di **kwargs, così kwargs sarà un Hash che potrai usare nella tua asserzione e non verranno generati avvisi…
Applicando la soluzione temporanea suggerita, le specifiche che fallivano diventano verdi.
https://github.com/yahonda/discourse/commit/356f15b02cb4a0bb869d19adf2a2018d07ee79bf
$ git diff main
diff --git a/spec/lib/backup_restore/shared_context_for_backup_restore.rb b/spec/lib/backup_restore/shared_context_for_backup_restore.rb
index 2ff78176ea..0fbc8ade15 100644
--- a/spec/lib/backup_restore/shared_context_for_backup_restore.rb
+++ b/spec/lib/backup_restore/shared_context_for_backup_restore.rb
@@ -33,7 +33,7 @@ shared_context "shared stuff" do
   def expect_db_migrate
-    Discourse::Utils.expects(:execute_command).with do |env, *command, **options|
+    Discourse::Utils.expects(:execute_command).with do |env, *command, options|
       env["SKIP_POST_DEPLOYMENT_MIGRATIONS"] == "0" &&
         env["SKIP_OPTIMIZE_ICONS"] == "1" &&
         env["DISABLE_TRANSLATION_OVERRIDES"] == "1" &&
Sono felice di aprire una pull request.
Aperto FIX: `BackupRestore::DatabaseRestorer` failures with Ruby 3 by yahonda · Pull Request #14580 · discourse/discourse · GitHub
