Ruby Gems Web Push not found
Users are experiencing a web-push gem not found error when updating Discourse, with the error pointing to a missing path in the bundle. yoursql719 reports the issue after updating, and Falco identifies a broken plugin (discourse-quick-messages) as a likely cause. znedw and others seek help to identify the problematic plugin, but full rebuild logs are required for diagnosis. yoursql719 shares a log file, and Falco requests the app.yml file to further investigate. The app.yml shows several plugins, including docker_manager and discourse-solved, but the problematic plugin may be discourse-locations or another one not listed.
Hi,
I´ve updated discourse to the latest version and now it won´t startup:
I, [2022-12-28T21:37:38.558813 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
[DEPRECATED] The `--deployment` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local deployment 'true'`, and stop using this flag
[DEPRECATED] The `--without` flag is deprecated because it relies on being remembered across bundler invocations, which bundler will no longer do in future versions. Instead please use `bundle config set --local without 'test development'`, and stop using this flag
Bundler::PathError: The path `/var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/web-push-369df8f475a4` does not exist.
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/source/path.rb:209:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/source/git.rb:211:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/source/path.rb:107:in `local_specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/source/git.rb:178:in `specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/lazy_specification.rb:82:in `materialize_for_installation'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:194:in `block in specs_for_dependency'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:194:in `map'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:194:in `specs_for_dependency'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:33:in `block in for'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:22:in `loop'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:22:in `for'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/spec_set.rb:79:in `materialize'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/definition.rb:209:in `missing_specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/definition.rb:213:in `missing_specs?'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/installer.rb:263:in `resolve_if_needed'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/installer.rb:82:in `block in run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/process_lock.rb:12:in `block in lock'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/process_lock.rb:9:in `open'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/process_lock.rb:9:in `lock'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/installer.rb:71:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/installer.rb:23:in `install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/cli/install.rb:62:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/cli.rb:257:in `block in install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/settings.rb:131:in `temporary'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/cli.rb:256:in `install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/cli.rb:31:in `dispatch'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/cli.rb:25:in `start'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/exe/bundle:48:in `block in <top (required)>'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/lib/bundler/friendly_errors.rb:120:in `with_friendly_errors'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.3.22/exe/bundle:36:in `<top (required)>'
I, [2022-12-28T21:38:17.995113 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.3.22
Frozen, using resolution from the lockfile
The definition is missing dependencies, failed to resolve & materialize locally (https://github.com/xfalcox/web-push (at openssl-3-compat@369df8f) is not yet checked out. Run `bundle install` first.)
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1098 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
Has anyone a hint for me? I haven´t changed any configuration for a while. I am using Debian 11.6 with docker version 20.10.22.
This is my app.yml:
templates:
  - "templates/web.socketed.template.yml"
#  - "templates/sshd.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
#  - "80:80"   # http
#  - "443:443" # https
   - "4001:22"
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  DISCOURSE_DEFAULT_LOCALE: de
  UNICORN_WORKERS: 8
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/angusmcleod/discourse-quick-messages
          - git clone https://github.com/discourse/discourse-solved
          - git clone https://github.com/angusmcleod/discourse-locations
          - git clone https://github.com/paviliondev/discourse-layouts.git
          - git clone https://github.com/discourse/discourse-signatures.git
run:
This is a known broken plugin, please remove and try again.
Thank you - the locations plugin is broken. The issue / error message persists, but discourse starts up.
I am getting the same issue, but I only have:
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
Please share the full rebuild logs.
Hi , I am new to discourse. I have same error/warning messages during the rebuilt today as in 2023-01-01, on OCI ARM server. The discourse runs ok though. Can you please let me know where is the rebuild logs. I have
production_errors.log production.log sidekiq.log unicorn.stderr.log unicorn.stdout.log
in my log folder, which one is the rebuild log?
Many thanks for the help!
Rebuild logs are the output of running ./launcher rebuild app on the host.
can someone help me determine which plugin is giving me the web-push error?
x86_64 arch detected.
Fetching origin
remote: Enumerating objects: 5, done.
remote: Counting objects: 100% (5/5), done.
remote: Total 5 (delta 2), reused 5 (delta 2), pack-reused 0
Unpacking objects: 100% (5/5), 1.64 KiB | 420.00 KiB/s, done.
From https://github.com/discourse/discourse_docker
 * [new branch]      build-27   -> origin/build-27
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
2.0.20221221-0050: Pulling from discourse/base
Digest: sha256:7ac6489e34a0f40f32457bffaa331940a98447b46451a6a1279a79868ee5420b
Status: Image is up to date for discourse/base:2.0.20221221-0050
docker.io/discourse/base:2.0.20221221-0050
/usr/local/lib/ruby/gems/3.1.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-01-06T09:56:37.862822 #1]  INFO -- : Reading from stdin
I, [2023-01-06T09:56:37.873432 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-01-06T09:56:37.916480 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-01-06T09:56:37.916796 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-01-06T09:56:37.920730 #1]  INFO -- :
I, [2023-01-06T09:56:37.921489 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-01-06T09:56:37.925468 #1]  INFO -- :
I, [2023-01-06T09:56:37.925768 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-01-06T09:56:37.929274 #1]  INFO -- :
I, [2023-01-06T09:56:37.929503 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-01-06T09:56:37.936629 #1]  INFO -- :
I, [2023-01-06T09:56:37.936917 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-01-06T09:56:37.942210 #1]  INFO -- :
I, [2023-01-06T09:56:37.942617 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/01/06 09:56:37 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2023-01-06T09:56:37.955798 #1]  INFO -- :
I, [2023-01-06T09:56:37.956293 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-01-06T09:56:37.961528 #1]  INFO -- :
I, [2023-01-06T09:56:37.962113 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-01-06T09:56:37.967246 #1]  INFO -- :
I, [2023-01-06T09:56:37.967766 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-01-06T09:56:37.972186 #1]  INFO -- :
I, [2023-01-06T09:56:37.972821 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-01-06T09:56:37.976397 #1]  INFO -- :
I, [2023-01-06T09:56:37.984067 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-01-06T09:56:37.992449 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-01-06T09:56:37.999761 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-01-06T09:56:38.008435 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-01-06T09:56:38.009072 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-01-06T09:56:39.996250 #1]  INFO -- :
I, [2023-01-06T09:56:39.996944 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/13/bin/initdb -D /shared/postgres_data || exit 0
I, [2023-01-06T09:56:40.001030 #1]  INFO -- :
I, [2023-01-06T09:56:40.001279 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-01-06T09:56:40.028125 #1]  INFO -- :
I, [2023-01-06T09:56:40.028920 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-01-06T09:56:40.032896 #1]  INFO -- :
I, [2023-01-06T09:56:40.033431 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-01-06T09:56:40.040148 #1]  INFO -- :
I, [2023-01-06T09:56:40.040814 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-01-06T09:56:40.044602 #1]  INFO -- :
I, [2023-01-06T09:56:40.046108 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' with data_directory = '/shared/postgres_data' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.047133 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addresses = '*' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.048699 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchronous_commit = $db_synchronous_commit in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.049489 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffers = $db_shared_buffers in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.051460 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work_mem in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.052387 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with default_text_search_config = '$db_default_text_search_config' in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.053139 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postgres_backup
I, [2023-01-06T09:56:40.060323 #1]  INFO -- :
I, [2023-01-06T09:56:40.061251 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoint_segments = $db_checkpoint_segments in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.062204 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_collector = $db_logging_collector in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.063149 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with log_min_duration_statement = $db_log_min_duration_statement in /etc/postgresql/13/main/postgresql.conf
I, [2023-01-06T09:56:40.064554 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) with local replication postgres  peer in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-06T09:56:40.065507 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all all 0.0.0.0/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-06T09:56:40.066299 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host all all ::/0 md5 in /etc/postgresql/13/main/pg_hba.conf
I, [2023-01-06T09:56:40.067025 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main
I, [2023-01-06T09:56:40.070647 #1]  INFO -- : > sleep 5
2023-01-06 09:56:40.147 UTC [42] LOG:  starting PostgreSQL 13.9 (Debian 13.9-1.pgdg110+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 10.2.1-6) 10.2.1 20210110, 64-bit
2023-01-06 09:56:40.148 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-01-06 09:56:40.148 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2023-01-06 09:56:40.150 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-01-06 09:56:40.156 UTC [45] LOG:  database system was shut down at 2023-01-06 09:56:28 UTC
2023-01-06 09:56:40.166 UTC [42] LOG:  database system is ready to accept connections
I, [2023-01-06T09:56:45.073997 #1]  INFO -- :
I, [2023-01-06T09:56:45.074652 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
2023-01-06 09:56:45.185 UTC [55] postgres@postgres ERROR:  database "discourse" already exists
2023-01-06 09:56:45.185 UTC [55] postgres@postgres STATEMENT:  CREATE DATABASE discourse;
createdb: error: database creation failed: ERROR:  database "discourse" already exists
I, [2023-01-06T09:56:45.188022 #1]  INFO -- :
I, [2023-01-06T09:56:45.188495 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse;"' || true
2023-01-06 09:56:45.267 UTC [59] postgres@discourse ERROR:  role "discourse" already exists
2023-01-06 09:56:45.267 UTC [59] postgres@discourse STATEMENT:  create user discourse;
I, [2023-01-06T09:56:45.271387 #1]  INFO -- :
I, [2023-01-06T09:56:45.272002 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-01-06T09:56:45.334691 #1]  INFO -- : GRANT
I, [2023-01-06T09:56:45.335171 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-01-06T09:56:45.396533 #1]  INFO -- : ALTER SCHEMA
I, [2023-01-06T09:56:45.396999 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists hstore;"'
NOTICE:  extension "hstore" already exists, skipping
I, [2023-01-06T09:56:45.475854 #1]  INFO -- : CREATE EXTENSION
I, [2023-01-06T09:56:45.476288 #1]  INFO -- : > su postgres -c 'psql template1 -c "create extension if not exists pg_trgm;"'
NOTICE:  extension "pg_trgm" already exists, skipping
I, [2023-01-06T09:56:45.540930 #1]  INFO -- : CREATE EXTENSION
I, [2023-01-06T09:56:45.541321 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists hstore;"'
I, [2023-01-06T09:56:45.604694 #1]  INFO -- : CREATE EXTENSION
I, [2023-01-06T09:56:45.605659 #1]  INFO -- : > su postgres -c 'psql discourse -c "create extension if not exists pg_trgm;"'
I, [2023-01-06T09:56:45.684519 #1]  INFO -- : CREATE EXTENSION
I, [2023-01-06T09:56:45.685169 #1]  INFO -- : > sudo -u postgres psql discourse
I, [2023-01-06T09:56:45.689551 #1]  INFO -- : update pg_database set encoding = pg_char_to_encoding('UTF8') where datname = 'discourse' AND encoding = pg_char_to_encoding('SQL_ASCII');
I, [2023-01-06T09:56:45.773054 #1]  INFO -- : File > /var/lib/postgresql/take-database-backup  chmod: +x  chown: postgres:postgres
I, [2023-01-06T09:56:45.777722 #1]  INFO -- : File > /var/spool/cron/crontabs/postgres  chmod:   chown:
I, [2023-01-06T09:56:45.778143 #1]  INFO -- : > echo postgres installed!
I, [2023-01-06T09:56:45.780994 #1]  INFO -- : postgres installed!
I, [2023-01-06T09:56:45.787429 #1]  INFO -- : File > /etc/service/redis/run  chmod: +x  chown:
I, [2023-01-06T09:56:45.793509 #1]  INFO -- : File > /etc/service/redis/log/run  chmod: +x  chown:
I, [2023-01-06T09:56:45.800521 #1]  INFO -- : File > /etc/runit/3.d/10-redis  chmod: +x  chown:
I, [2023-01-06T09:56:45.802279 #1]  INFO -- : Replacing daemonize yes with  in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.803245 #1]  INFO -- : Replacing (?-mix:^pidfile.*$) with  in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.803992 #1]  INFO -- : > install -d -m 0755 -o redis -g redis /shared/redis_data
I, [2023-01-06T09:56:45.808325 #1]  INFO -- :
I, [2023-01-06T09:56:45.809392 #1]  INFO -- : Replacing (?-mix:^logfile.*$) with logfile "" in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.810316 #1]  INFO -- : Replacing (?-mix:^bind .*$) with  in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.811139 #1]  INFO -- : Replacing (?-mix:^dir .*$) with dir /shared/redis_data in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.812249 #1]  INFO -- : Replacing (?-mix:^protected-mode yes) with protected-mode no in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.817079 #1]  INFO -- : Replacing # io-threads 4 with io-threads $redis_io_threads in /etc/redis/redis.conf
I, [2023-01-06T09:56:45.817912 #1]  INFO -- : > echo redis installed
I, [2023-01-06T09:56:45.821678 #1]  INFO -- : redis installed
I, [2023-01-06T09:56:45.822096 #1]  INFO -- : > cat /etc/redis/redis.conf | grep logfile
I, [2023-01-06T09:56:45.827204 #1]  INFO -- : logfile ""
I, [2023-01-06T09:56:45.827701 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.confI, [2023-01-06T09:56:45.829988 #1]  INFO -- : > sleep 10
103:C 06 Jan 2023 09:56:45.837 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
103:C 06 Jan 2023 09:56:45.837 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=103, just started
103:C 06 Jan 2023 09:56:45.837 # Configuration loaded
103:M 06 Jan 2023 09:56:45.838 * monotonic clock: POSIX clock_gettime
103:M 06 Jan 2023 09:56:45.839 * Running mode=standalone, port=6379.
103:M 06 Jan 2023 09:56:45.839 # Server initialized
103:M 06 Jan 2023 09:56:45.840 # WARNING Memory overcommit must be enabled! Without it, a background save or replication may fail under low memory condition. Being disabled, it can can also cause failures without low memory condition, see https://github.com/jemalloc/jemalloc/issues/1328. To fix this issue add 'vm.overcommit_memory = 1' to /etc/sysctl.conf and then reboot or run the command 'sysctl vm.overcommit_memory=1' for this to take effect.
103:M 06 Jan 2023 09:56:45.840 * Loading RDB produced by version 7.0.7
103:M 06 Jan 2023 09:56:45.840 * RDB age 18 seconds
103:M 06 Jan 2023 09:56:45.840 * RDB memory usage when created 62.75 Mb
103:M 06 Jan 2023 09:56:46.126 * Done loading RDB, keys loaded: 42875, keys expired: 25.
103:M 06 Jan 2023 09:56:46.126 * DB loaded from disk: 0.285 seconds
103:M 06 Jan 2023 09:56:46.126 * Ready to accept connections
I, [2023-01-06T09:56:55.833137 #1]  INFO -- :
I, [2023-01-06T09:56:55.833631 #1]  INFO -- : > thpoff echo "thpoff is installed!"
I, [2023-01-06T09:56:55.838644 #1]  INFO -- : thpoff is installed!
I, [2023-01-06T09:56:55.839000 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_SMTP_ADDRESS"] == "smtp.example.com"; puts "Aborting! Mail is not configured!"; exit 1; end'
I, [2023-01-06T09:56:55.937009 #1]  INFO -- :
I, [2023-01-06T09:56:55.937523 #1]  INFO -- : > /usr/local/bin/ruby -e 'if ENV["DISCOURSE_HOSTNAME"] == "discourse.example.com"; puts "Aborting! Domain is not configured!"; exit 1; end'
I, [2023-01-06T09:56:56.055190 #1]  INFO -- :
I, [2023-01-06T09:56:56.056052 #1]  INFO -- : > /usr/local/bin/ruby -e 'if (ENV["DISCOURSE_CDN_URL"] || "")[0..1] == "//"; puts "Aborting! CDN must have a protocol specified. Once fixed you should rebake your posts now to correct all posts."; exit 1; end'
I, [2023-01-06T09:56:56.165960 #1]  INFO -- :
I, [2023-01-06T09:56:56.166528 #1]  INFO -- : > rm -f /etc/cron.d/anacron
I, [2023-01-06T09:56:56.170055 #1]  INFO -- :
I, [2023-01-06T09:56:56.173793 #1]  INFO -- : File > /etc/cron.d/anacron  chmod:   chown:
I, [2023-01-06T09:56:56.179969 #1]  INFO -- : File > /etc/runit/1.d/copy-env  chmod: +x  chown:
I, [2023-01-06T09:56:56.186007 #1]  INFO -- : File > /etc/service/unicorn/run  chmod: +x  chown:
I, [2023-01-06T09:56:56.191686 #1]  INFO -- : File > /etc/service/nginx/run  chmod: +x  chown:
I, [2023-01-06T09:56:56.197830 #1]  INFO -- : File > /etc/runit/3.d/01-nginx  chmod: +x  chown:
I, [2023-01-06T09:56:56.204069 #1]  INFO -- : File > /etc/runit/3.d/02-unicorn  chmod: +x  chown:
I, [2023-01-06T09:56:56.204477 #1]  INFO -- : Replacing # postgres with sv start postgres || exit 1 in /etc/service/unicorn/run
I, [2023-01-06T09:56:56.204950 #1]  INFO -- : > exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.confI, [2023-01-06T09:56:56.208008 #1]  INFO -- : > cd /var/www/discourse && git reset --hard
130:C 06 Jan 2023 09:56:56.214 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
130:C 06 Jan 2023 09:56:56.214 # Redis version=7.0.7, bits=64, commit=00000000, modified=0, pid=130, just started
130:C 06 Jan 2023 09:56:56.214 # Configuration loaded
130:M 06 Jan 2023 09:56:56.215 * monotonic clock: POSIX clock_gettime
130:M 06 Jan 2023 09:56:56.216 # Warning: Could not create server TCP listening socket *:6379: bind: Address already in use
130:M 06 Jan 2023 09:56:56.216 # Failed listening on port 6379 (TCP), aborting.
Updating files: 100% (32637/32637), done.
I, [2023-01-06T09:57:00.148769 #1]  INFO -- : HEAD is now at e775ed1c DEV: Properly include spec examples (#19532)
I, [2023-01-06T09:57:00.148996 #1]  INFO -- : > cd /var/www/discourse && git clean -f
I, [2023-01-06T09:57:00.298213 #1]  INFO -- :
I, [2023-01-06T09:57:00.298417 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches --add origin main
I, [2023-01-06T09:57:00.303868 #1]  INFO -- :
I, [2023-01-06T09:57:00.304305 #1]  INFO -- : > cd /var/www/discourse && git remote set-branches origin tests-passed
I, [2023-01-06T09:57:00.308952 #1]  INFO -- :
I, [2023-01-06T09:57:00.309534 #1]  INFO -- : > cd /var/www/discourse && git fetch --depth 1 origin tests-passed
 * branch              tests-passed -> FETCH_HEAD
 * [new branch]        tests-passed -> origin/tests-passed
I, [2023-01-06T09:57:02.291480 #1]  INFO -- :
I, [2023-01-06T09:57:02.292020 #1]  INFO -- : > cd /var/www/discourse && git checkout tests-passed
Switched to a new branch 'tests-passed'
I, [2023-01-06T09:57:02.778403 #1]  INFO -- : Branch 'tests-passed' set up to track remote branch 'tests-passed' from 'origin'.
I, [2023-01-06T09:57:02.778757 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp
I, [2023-01-06T09:57:02.783573 #1]  INFO -- :
I, [2023-01-06T09:57:02.783852 #1]  INFO -- : > cd /var/www/discourse && chown discourse:www-data tmp
I, [2023-01-06T09:57:02.788155 #1]  INFO -- :
I, [2023-01-06T09:57:02.788374 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/pids
I, [2023-01-06T09:57:02.793490 #1]  INFO -- :
I, [2023-01-06T09:57:02.793745 #1]  INFO -- : > cd /var/www/discourse && mkdir -p tmp/sockets
I, [2023-01-06T09:57:02.798955 #1]  INFO -- :
I, [2023-01-06T09:57:02.799276 #1]  INFO -- : > cd /var/www/discourse && touch tmp/.gitkeep
I, [2023-01-06T09:57:02.804037 #1]  INFO -- :
I, [2023-01-06T09:57:02.804158 #1]  INFO -- : > cd /var/www/discourse && mkdir -p                    /shared/log/rails
I, [2023-01-06T09:57:02.809532 #1]  INFO -- :
I, [2023-01-06T09:57:02.810042 #1]  INFO -- : > cd /var/www/discourse && bash -c "touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log"
I, [2023-01-06T09:57:02.816507 #1]  INFO -- :
I, [2023-01-06T09:57:02.817103 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log /var/www/discourse/log"
I, [2023-01-06T09:57:02.823217 #1]  INFO -- :
I, [2023-01-06T09:57:02.823371 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/{uploads,backups}"
I, [2023-01-06T09:57:02.830664 #1]  INFO -- :
I, [2023-01-06T09:57:02.831217 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/{uploads,backups} /var/www/discourse/public"
I, [2023-01-06T09:57:02.838035 #1]  INFO -- :
I, [2023-01-06T09:57:02.838188 #1]  INFO -- : > cd /var/www/discourse && bash -c "mkdir -p           /shared/tmp/{backups,restores}"
I, [2023-01-06T09:57:02.845017 #1]  INFO -- :
I, [2023-01-06T09:57:02.845161 #1]  INFO -- : > cd /var/www/discourse && bash -c "ln    -s           /shared/tmp/{backups,restores} /var/www/discourse/tmp"
I, [2023-01-06T09:57:02.852142 #1]  INFO -- :
I, [2023-01-06T09:57:02.852719 #1]  INFO -- : > cd /var/www/discourse && chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp
I, [2023-01-06T09:57:03.088067 #1]  INFO -- :
I, [2023-01-06T09:57:03.088676 #1]  INFO -- : > cd /var/www/discourse && [ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete
I, [2023-01-06T09:57:03.096456 #1]  INFO -- :
I, [2023-01-06T09:57:03.097157 #1]  INFO -- : Replacing # redis with sv start redis || exit 1 in /etc/service/unicorn/run
I, [2023-01-06T09:57:03.098182 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/docker_manager.git
Cloning into 'docker_manager'...
I, [2023-01-06T09:57:04.007060 #1]  INFO -- :
I, [2023-01-06T09:57:04.007276 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-whos-online.git
Cloning into 'discourse-whos-online'...
I, [2023-01-06T09:57:04.533307 #1]  INFO -- :
I, [2023-01-06T09:57:04.533437 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/tarck-bike/discourse-poster-location.git
Cloning into 'discourse-poster-location'...
I, [2023-01-06T09:57:04.827646 #1]  INFO -- :
I, [2023-01-06T09:57:04.827830 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/tarck-bike/discourse-word-replace.git
Cloning into 'discourse-word-replace'...
I, [2023-01-06T09:57:05.157347 #1]  INFO -- :
I, [2023-01-06T09:57:05.157476 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-reactions.git
Cloning into 'discourse-reactions'...
I, [2023-01-06T09:57:06.028406 #1]  INFO -- :
I, [2023-01-06T09:57:06.029058 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-prometheus.git
Cloning into 'discourse-prometheus'...
I, [2023-01-06T09:57:06.487202 #1]  INFO -- :
I, [2023-01-06T09:57:06.487327 #1]  INFO -- : > cd /var/www/discourse/plugins && git clone https://github.com/discourse/discourse-gamification.git
Cloning into 'discourse-gamification'...
I, [2023-01-06T09:57:06.937075 #1]  INFO -- :
I, [2023-01-06T09:57:06.938007 #1]  INFO -- : > cp /var/www/discourse/config/nginx.sample.conf /etc/nginx/conf.d/discourse.conf
I, [2023-01-06T09:57:06.943289 #1]  INFO -- :
I, [2023-01-06T09:57:06.944013 #1]  INFO -- : > rm /etc/nginx/sites-enabled/default
I, [2023-01-06T09:57:06.947967 #1]  INFO -- :
I, [2023-01-06T09:57:06.948611 #1]  INFO -- : > mkdir -p /var/nginx/cache
I, [2023-01-06T09:57:06.952672 #1]  INFO -- :
I, [2023-01-06T09:57:06.953780 #1]  INFO -- : Replacing pid /run/nginx.pid; with daemon off; in /etc/nginx/nginx.conf
I, [2023-01-06T09:57:06.954545 #1]  INFO -- : Replacing (?m-ix:upstream[^\}]+\}) with upstream discourse { server 127.0.0.1:3000; } in /etc/nginx/conf.d/discourse.conf
I, [2023-01-06T09:57:06.955128 #1]  INFO -- : Replacing (?-mix:server_name.+$) with server_name _ ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-06T09:57:06.955894 #1]  INFO -- : Replacing (?-mix:client_max_body_size.+$) with client_max_body_size $upload_size ; in /etc/nginx/conf.d/discourse.conf
I, [2023-01-06T09:57:06.956428 #1]  INFO -- : Replacing (?-mix:worker_connections.+$) with worker_connections $nginx_worker_connections ; in /etc/nginx/nginx.conf
I, [2023-01-06T09:57:06.956934 #1]  INFO -- : > echo "done configuring web"
I, [2023-01-06T09:57:06.960192 #1]  INFO -- : done configuring web
I, [2023-01-06T09:57:06.960696 #1]  INFO -- : > cd /var/www/discourse && gem install bundler --conservative -v $(awk '/BUNDLED WITH/ { getline; gsub(/ /,""); print $0 }' Gemfile.lock)
I, [2023-01-06T09:57:07.752125 #1]  INFO -- : Successfully installed bundler-2.4.1
1 gem installed
I, [2023-01-06T09:57:07.752250 #1]  INFO -- : > cd /var/www/discourse && find /var/www/discourse ! -user discourse -exec chown discourse {} \+
I, [2023-01-06T09:57:18.492684 #1]  INFO -- :
I, [2023-01-06T09:57:18.493382 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'yarn install --production --frozen-lockfile && yarn cache clean'
warning " > @mixer/parallel-prettier@2.0.3" has unmet peer dependency "prettier@^2.0.0".
warning "eslint-config-discourse > eslint-plugin-lodash@7.1.0" has unmet peer dependency "lodash@>=4".
I, [2023-01-06T09:58:36.178866 #1]  INFO -- : yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts/discourse $(node -e 'if(JSON.parse(process.env.npm_config_argv).original.includes(`--frozen-lockfile`)){console.log(`--frozen-lockfile`)}')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
[4/4] Building fresh packages...
Done in 43.67s.
Done in 70.48s.
yarn cache v1.22.19
success Cleared cache.
Done in 6.41s.
I, [2023-01-06T09:58:36.179801 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle install --deployment --retry 3 --jobs 4 --verbose --without test development'
/usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:209:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:205:in `load_spec_files'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/path.rb:107:in `local_specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source/git.rb:172:in `specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/lazy_specification.rb:86:in `materialize_for_installation'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `map!'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:195:in `specs_for_dependency'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:33:in `block in for'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `loop'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:22:in `for'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/spec_set.rb:79:in `materialize'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/definition.rb:198:in `missing_specs'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/definition.rb:202:in `missing_specs?'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:253:in `resolve_if_needed'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:82:in `block in run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:12:in `block in lock'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `open'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/process_lock.rb:9:in `lock'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:71:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/installer.rb:23:in `install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli/install.rb:62:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:260:in `block in install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/settings.rb:131:in `temporary'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:259:in `install'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:34:in `dispatch'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/cli.rb:28:in `start'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/exe/bundle:45:in `block in <top (required)>'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
  /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/exe/bundle:33:in `<top (required)>'
I, [2023-01-06T09:59:30.411465 #1]  INFO -- : Running `bundle install --deployment --jobs 4 --retry 3 --verbose --without "test" "development"` with bundler 2.4.1
HTTP GET https://index.rubygems.org/versions
HTTP 206 Partial Content https://index.rubygems.org/versions
Fetching gem metadata from https://rubygems.org/
Looking up gems ["actionmailer", "actionpack", "actionview", "actionview_precompiler", "active_model_serializers", "activejob", "activemodel", "activerecord", "activesupport", "addressable", "annotate", "ast", "aws-eventstream", "aws-partitions", "aws-sdk-core", "aws-sdk-kms", "aws-sdk-s3", "aws-sdk-sns", "aws-sigv4", "better_errors", "binding_of_caller", "bootsnap", "builder", "bullet", "byebug", "capybara", "cbor", "certified", "cgi", "chunky_png", "coderay", "colored2", "concurrent-ruby", "connection_pool", "cose", "cppjieba_rb", "crack", "crass", "css_parser", "debug_inspector", "diff-lcs", "diffy", "digest", "discourse-fonts", "discourse-seed-fu", "discourse_dev_assets", "docile", "ecma-re-validator", "email_reply_trimmer", "erubi", "excon", "execjs", "exifr", "fabrication", "faker", "fakeweb", "faraday", "faraday-net_http", "faraday-retry", "fast_blank", "fast_xs", "fastimage", "ffi", "fspath", "gc_tracer", "globalid", "guess_html_encoding", "hana", "hashdiff", "hashie", "highline", "hkdf", "htmlentities", "http_accept_language", "i18n", "image_optim", "image_size", "in_threads", "jmespath", "json", "json-schema", "json_schemer", "jwt", "kgio", "libv8-node", "listen", "literate_randomizer", "lograge", "logstash-event", "logstash-logger", "logster", "loofah", "lru_redux", "lz4-ruby", "matrix", "maxminddb", "memory_profiler", "message_bus", "method_source", "mini_mime", "mini_portile2", "mini_racer", "mini_scheduler", "mini_sql", "mini_suffix", "minitest", "mocha", "msgpack", "multi_json", "multi_xml", "mustache", "net-http", "net-imap", "net-pop", "net-protocol", "net-smtp", "nio4r", "nokogiri", "oauth", "oauth-tty", "oauth2", "oj", "omniauth", "omniauth-facebook", "omniauth-github", "omniauth-google-oauth2", "omniauth-oauth", "omniauth-oauth2", "omniauth-twitter", "openssl", "openssl-signature_algorithm", "optimist", "parallel", "parallel_tests", "parser", "pg", "progress", "pry", "pry-byebug", "pry-rails", "public_suffix", "puma", "r2", "racc", "rack", "rack-mini-profiler", "rack-protection", "rack-test", "rails-dom-testing", "rails-html-sanitizer", "rails_failover", "rails_multisite", "railties", "rainbow", "raindrops", "rake", "rb-fsevent", "rb-inotify", "rbtrace", "rchardet", "redis", "redis-namespace", "regexp_parser", "request_store", "rexml", "rinku", "rotp", "rqrcode", "rqrcode_core", "rspec", "rspec-core", "rspec-expectations", "rspec-html-matchers", "rspec-mocks", "rspec-rails", "rspec-support", "rss", "rswag-specs", "rubocop", "rubocop-ast", "rubocop-discourse", "rubocop-rspec", "ruby-prof", "ruby-progressbar", "ruby-readability", "ruby2_keywords", "rubyzip", "sanitize", "sassc", "sassc-rails", "selenium-webdriver", "shoulda-matchers", "sidekiq", "simplecov", "simplecov-html", "simplecov_json_formatter", "snaky_hash", "sprockets", "sprockets-rails", "sshkey", "stackprof", "test-prof", "thor", "tilt", "timeout", "tzinfo", "uglifier", "unf", "unf_ext", "unicode-display_width", "unicorn", "uniform_notifier", "uri", "uri_template", "version_gem", "webdrivers", "webmock", "webrick", "websocket", "xorcist", "xpath", "yaml-lint", "zeitwerk"]
HTTP GET https://index.rubygems.org/info/aws-partitions
HTTP 206 Partial Content https://index.rubygems.org/info/aws-partitions
HTTP GET https://index.rubygems.org/info/bullet
HTTP 206 Partial Content https://index.rubygems.org/info/bullet
HTTP GET https://index.rubygems.org/info/cgi
HTTP 200 OK https://index.rubygems.org/info/cgi
HTTP GET https://index.rubygems.org/info/css_parser
HTTP 206 Partial Content https://index.rubygems.org/info/css_parser
HTTP GET https://index.rubygems.org/info/erubi
HTTP GET https://index.rubygems.org/info/excon
HTTP 206 Partial Content https://index.rubygems.org/info/erubi
HTTP 206 Partial Content https://index.rubygems.org/info/excon
HTTP GET https://index.rubygems.org/info/faker
HTTP 206 Partial Content https://index.rubygems.org/info/faker
HTTP GET https://index.rubygems.org/info/highline
HTTP 206 Partial Content https://index.rubygems.org/info/highline
HTTP GET https://index.rubygems.org/info/jwt
HTTP 206 Partial Content https://index.rubygems.org/info/jwt
HTTP GET https://index.rubygems.org/info/mini_portile2
HTTP 206 Partial Content https://index.rubygems.org/info/mini_portile2
HTTP GET https://index.rubygems.org/info/minitest
HTTP 206 Partial Content https://index.rubygems.org/info/minitest
HTTP GET https://index.rubygems.org/info/net-imap
HTTP 206 Partial Content https://index.rubygems.org/info/net-imap
HTTP GET https://index.rubygems.org/info/nokogiri
HTTP 206 Partial Content https://index.rubygems.org/info/nokogiri
HTTP GET https://index.rubygems.org/info/openssl
HTTP 206 Partial Content https://index.rubygems.org/info/openssl
HTTP GET https://index.rubygems.org/info/parser
HTTP 206 Partial Content https://index.rubygems.org/info/parser
HTTP GET https://index.rubygems.org/info/puma
HTTP GET https://index.rubygems.org/info/racc
HTTP 206 Partial Content https://index.rubygems.org/info/puma
HTTP 206 Partial Content https://index.rubygems.org/info/racc
HTTP GET https://index.rubygems.org/info/rack
HTTP 206 Partial Content https://index.rubygems.org/info/rack
HTTP GET https://index.rubygems.org/info/redis-namespace
HTTP 206 Partial Content https://index.rubygems.org/info/redis-namespace
HTTP GET https://index.rubygems.org/info/rubocop
HTTP GET https://index.rubygems.org/info/rubocop-ast
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop
HTTP 206 Partial Content https://index.rubygems.org/info/rubocop-ast
HTTP GET https://index.rubygems.org/info/ruby-prof
HTTP 206 Partial Content https://index.rubygems.org/info/ruby-prof
HTTP GET https://index.rubygems.org/info/simplecov
HTTP 206 Partial Content https://index.rubygems.org/info/simplecov
HTTP GET https://index.rubygems.org/info/unicode-display_width
HTTP 206 Partial Content https://index.rubygems.org/info/unicode-display_width
Looking up gems ["mail", "text-format", "erubis", "rack-mount", "rack-cache", "journey", "rails-deprecated_sanitizer", "jsonapi", "case_transform", "jsonapi-renderer", "activemodel-globalid", "bcrypt-ruby", "arel", "activerecord-deprecated_finders", "memcache-client", "thread_safe", "jamespath", "http-2", "aws-crt", "rouge", "snappy", "columnize", "debugger-linecache", "slop", "rb-readline", "culerity", "database_cleaner", "mime-types", "celerity", "functional-ruby", "ref", "safe_yaml", "rdoc", "rcov", "multipart-post", "faraday-excon", "faraday-net_http_persistent", "faraday-em_http", "faraday-em_synchrony", "faraday-httpclient", "faraday-patron", "faraday-rack", "faraday-multipart", "pastel", "tty-pager", "tty-screen", "tty-tree", "rake-compiler", "rb-appscript", "xattr", "ffi-xattr", "termios", "json_pure", "rdf", "rb-fchange", "rb-kqueue", "celluloid", "celluloid-io", "ruby_dep", "stud", "ruby_parser", "eventmachine", "thin", "libv8", "net-ftp", "metaclass", "io-wait", "strscan", "date", "ruby-hmac", "faraday-middleware", "httpauth", "rash_alt", "bigdecimal", "oa-core", "oa-oauth", "oa-openid", "oa-basic", "oa-enterprise", "oa-more", "hoe", "weakling", "mini_portile", "pkg-config", "ipaddr", "sexp_processor", "pry-doc", "win32console", "yard", "spoon", "escape_utils", "rails", "rack-ssl", "trollop", "redis-client", "base32", "webrat", "rspec-collection_matchers", "term-ansicolor", "backports", "powerpack", "astrolabe", "tins", "jaro_winkler", "psych", "hpricot", "nokogumbo", "bundler", "sass", "childprocess", "libwebsocket", "bourne", "compass", "sprockets-sass", "sinatra", "slim", "lockfile", "hike", "therubyracer", "archive-zip", "zip", "net_http_ssl_fix"]
HTTP GET https://index.rubygems.org/info/pry-doc
HTTP 206 Partial Content https://index.rubygems.org/info/pry-doc
HTTP GET https://index.rubygems.org/info/bundler
HTTP 206 Partial Content https://index.rubygems.org/info/bundler
Looking up gems ["text-hyphen", "treetop", "tlsmail", "multimap", "abstract", "jsonapi-parser", "bcrypt", "ZenTest", "RubyInline", "atomic", "snappy-jars", "ruby_core_source", "debugger-ruby_core_source", "cucumber", "database_cleaner-active_record", "mime-types-data", "net-http-persistent", "httpclient", "patron", "equatable", "tty-color", "tty-which", "verse", "strings", "spruz", "link_header", "hamster", "win32-api", "timers", "facter", "celluloid-essentials", "celluloid-extras", "celluloid-fsm", "celluloid-pool", "celluloid-supervision", "dotenv", "nenv", "rspec-logsplit", "metriks", "ParseTree", "daemons", "time", "rack-openid", "ruby-openid-apps-discovery", "restclient", "rest-client", "net-ldap", "rubyntlm", "pyu-ruby-sasl", "uuid", "XMLCanonicalizer", "rubyforge", "gemcutter", "activeresource", "actionwebservice", "actioncable", "activestorage", "actionmailbox", "actiontext", "curses", "sync", "jar-dependencies", "stringio", "sass-listen", "haml", "fssm", "compass-core", "compass-import-once", "sprockets-helpers", "mongrel", "mustermann", "temple", "io-like"]
Looking up gems ["facets", "polyglot", "archive-tar-minitar", "gherkin", "multi_test", "cucumber-core", "gherkin3", "cucumber-wire", "event-bus", "cucumber-expressions", "cucumber-formatter-dots", "cucumber-gherkin", "cucumber-html-formatter", "cucumber-cucumber-expressions", "cucumber-messages", "sys-uname", "cucumber-create-meta", "cucumber-ci-environment", "database_cleaner-core", "unicode_utils", "strings-ansi", "test-unit", "hitimes", "CFPropertyList", "sys-admin", "win32-dir", "windows-api", "windows-pr", "win32-security", "hocon", "celluloid-gems", "coveralls", "dotenv-deployment", "rbtree", "faraday_middleware", "yajl-ruby", "avl_tree", "SexpProcessor", "ruby-openid", "netrc", "http-cookie", "http-accept", "macaddr", "log4r", "net-scp", "rails-observers", "activemodel-serializers-xml", "coffee-rails", "em-hiredis", "faye-websocket", "websocket-driver", "marcel", "mimemagic", "ruby-maven", "cgi_multipart_eof_fix", "fastthread", "gem_plugin", "tool"]
HTTP GET https://index.rubygems.org/info/cucumber-core
HTTP GET https://index.rubygems.org/info/cucumber-gherkin
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-core
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-gherkin
Looking up gems ["minitar", "minitar-cli", "c21e", "os", "cucumber-tag_expressions", "cucumber-tag-expressions", "google-protobuf", "protobuf-cucumber", "power_assert", "configuration", "mkrf", "libxml-ruby", "ffi-win32-extensions", "colorize", "roauth", "ruby-yadis", "domain_name", "sqlite3", "systemu", "net-ssh", "coffee-script", "hiredis", "websocket-extensions", "maven-tools", "ruby-maven-libs"]
HTTP GET https://index.rubygems.org/info/cucumber-tag-expressions
HTTP 206 Partial Content https://index.rubygems.org/info/cucumber-tag-expressions
HTTP GET https://index.rubygems.org/info/power_assert
HTTP 206 Partial Content https://index.rubygems.org/info/power_assert
HTTP GET https://index.rubygems.org/info/libxml-ruby
HTTP 206 Partial Content https://index.rubygems.org/info/libxml-ruby
HTTP GET https://index.rubygems.org/info/sqlite3
HTTP 206 Partial Content https://index.rubygems.org/info/sqlite3
Looking up gems ["powerbar", "middleware", "pattern-match", "needle", "jruby-pageant", "bcrypt_pbkdf", "rbnacl", "rbnacl-libsodium", "coffee-script-source", "virtus"]
Looking up gems ["ansi", "descendants_tracker", "axiom-types", "coercible", "equalizer"]
Looking up gems ["ice_nine", "adamantium"]
Looking up gems ["memoizable"]
Fetching https://github.com/xfalcox/web-push
Using rake 13.0.6
0:  rake (13.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rake-13.0.6.gemspec
Using concurrent-ruby 1.1.10
0:  concurrent-ruby (1.1.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/concurrent-ruby-1.1.10.gemspec
Using builder 3.2.4
1:  builder (3.2.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/builder-3.2.4.gemspec
Using erubi 1.11.0
1:  erubi (1.11.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/erubi-1.11.0.gemspec
Fetching racc 1.6.2
Fetching rack 2.2.5
Fetching minitest 5.17.0
Using crass 1.0.6
2:  crass (1.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/crass-1.0.6.gemspec
Using mini_mime 1.1.2
2:  mini_mime (1.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_mime-1.1.2.gemspec
Using timeout 0.3.1
2:  timeout (0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/timeout-0.3.1.gemspec
Using public_suffix 5.0.1
2:  public_suffix (5.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/public_suffix-5.0.1.gemspec
Using aws-eventstream 1.2.0
2:  aws-eventstream (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-eventstream-1.2.0.gemspec
Using aws-partitions 1.583.0
2:  aws-partitions (1.583.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-partitions-1.583.0.gemspec
Using jmespath 1.6.2
2:  jmespath (1.6.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/jmespath-1.6.2.gemspec
Using msgpack 1.6.0
2:  msgpack (1.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/msgpack-1.6.0.gemspec
Using bundler 2.4.1
2:  bundler (2.4.1) from /usr/local/lib/ruby/gems/3.1.0/gems/bundler-2.4.1/lib/bundler/source
Using byebug 11.1.3
2:  byebug (11.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/byebug-11.1.3.gemspec
Using cbor 0.5.9.6
2:  cbor (0.5.9.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cbor-0.5.9.6.gemspec
Fetching cgi 0.3.6
Installing cgi 0.3.6 with native extensions
Installing minitest 5.17.0
Installing racc 1.6.2 with native extensions
Installing rack 2.2.5
Building native extensions. This could take a while...
0:  minitest (5.17.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/minitest-5.17.0.gemspec
Using chunky_png 1.4.0
0:  chunky_png (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/chunky_png-1.4.0.gemspec
Using coderay 1.1.3
0:  coderay (1.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/coderay-1.1.3.gemspec
Using colored2 3.1.2
0:  colored2 (3.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/colored2-3.1.2.gemspec
Using connection_pool 2.3.0
0:  connection_pool (2.3.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/connection_pool-2.3.0.gemspec
Fetching openssl 3.0.2
Installing openssl 3.0.2 with native extensions
3:  rack (2.2.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-2.2.5.gemspec
Using cppjieba_rb 0.4.2
3:  cppjieba_rb (0.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cppjieba_rb-0.4.2.gemspec
Using diffy 3.4.2
3:  diffy (3.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/diffy-3.4.2.gemspec
Using digest 3.1.1
3:  digest (3.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/digest-3.1.1.gemspec
Using discourse-fonts 0.0.9
3:  discourse-fonts (0.0.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/discourse-fonts-0.0.9.gemspec
Using regexp_parser 2.6.1
3:  regexp_parser (2.6.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/regexp_parser-2.6.1.gemspec
Using email_reply_trimmer 0.1.13
3:  email_reply_trimmer (0.1.13) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/email_reply_trimmer-0.1.13.gemspec
Fetching excon 0.96.0
Installing excon 0.96.0
3:  excon (0.96.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/excon-0.96.0.gemspec
Using execjs 2.8.1
3:  execjs (2.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/execjs-2.8.1.gemspec
Using exifr 1.3.10
3:  exifr (1.3.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/exifr-1.3.10.gemspec
Using faraday-net_http 3.0.2
3:  faraday-net_http (3.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-net_http-3.0.2.gemspec
Using ruby2_keywords 0.0.5
3:  ruby2_keywords (0.0.5) from /usr/local/lib/ruby/gems/3.1.0/specifications/default/ruby2_keywords-0.0.5.gemspec
Using fast_blank 1.0.1
3:  fast_blank (1.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fast_blank-1.0.1.gemspec
Using fast_xs 0.8.0
3:  fast_xs (0.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fast_xs-0.8.0.gemspec
Using fastimage 2.2.6
3:  fastimage (2.2.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fastimage-2.2.6.gemspec
Using ffi 1.15.5
3:  ffi (1.15.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ffi-1.15.5.gemspec
Using fspath 3.1.2
3:  fspath (3.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/fspath-3.1.2.gemspec
Using gc_tracer 1.5.1
3:  gc_tracer (1.5.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/gc_tracer-1.5.1.gemspec
Using guess_html_encoding 0.0.11
3:  guess_html_encoding (0.0.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/guess_html_encoding-0.0.11.gemspec
Using hana 1.3.7
3:  hana (1.3.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hana-1.3.7.gemspec
Using hashie 5.0.0
3:  hashie (5.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hashie-5.0.0.gemspec
Fetching highline 2.1.0
Installing highline 2.1.0
3:  highline (2.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/highline-2.1.0.gemspec
Fetching hkdf 1.0.0
Installing hkdf 1.0.0
3:  hkdf (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/hkdf-1.0.0.gemspec
Using htmlentities 4.3.4
3:  htmlentities (4.3.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/htmlentities-4.3.4.gemspec
Using http_accept_language 2.1.1
3:  http_accept_language (2.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/http_accept_language-2.1.1.gemspec
Using image_size 3.2.0
3:  image_size (3.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/image_size-3.2.0.gemspec
Using in_threads 1.6.0
3:  in_threads (1.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/in_threads-1.6.0.gemspec
Using progress 3.6.0
3:  progress (3.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/progress-3.6.0.gemspec
Using json 2.6.3
3:  json (2.6.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/json-2.6.3.gemspec
Using uri_template 0.7.0
3:  uri_template (0.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uri_template-0.7.0.gemspec
Fetching jwt 2.6.0
Installing jwt 2.6.0
3:  jwt (2.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/jwt-2.6.0.gemspec
Using kgio 2.11.4
3:  kgio (2.11.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/kgio-2.11.4.gemspec
Using libv8-node 16.10.0.0 (x86_64-linux)
3:  libv8-node (16.10.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/libv8-node-16.10.0.0-x86_64-linux.gemspec
Using method_source 1.0.0
3:  method_source (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/method_source-1.0.0.gemspec
Using thor 1.2.1
3:  thor (1.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/thor-1.2.1.gemspec
Using zeitwerk 2.6.6
3:  zeitwerk (2.6.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/zeitwerk-2.6.6.gemspec
Using logstash-event 1.2.02
3:  logstash-event (1.2.02) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logstash-event-1.2.02.gemspec
Using logster 2.11.3
3:  logster (2.11.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logster-2.11.3.gemspec
Using lru_redux 1.1.0
3:  lru_redux (1.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lru_redux-1.1.0.gemspec
Using lz4-ruby 0.3.3
3:  lz4-ruby (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lz4-ruby-0.3.3.gemspec
Using maxminddb 0.1.22
3:  maxminddb (0.1.22) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/maxminddb-0.1.22.gemspec
Using memory_profiler 1.0.1
3:  memory_profiler (1.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/memory_profiler-1.0.1.gemspec
Using redis 4.8.0
3:  redis (4.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/redis-4.8.0.gemspec
Using mini_sql 1.4.0
3:  mini_sql (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_sql-1.4.0.gemspec
Using multi_json 1.15.0
3:  multi_json (1.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/multi_json-1.15.0.gemspec
Using multi_xml 0.6.0
3:  multi_xml (0.6.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/multi_xml-0.6.0.gemspec
Using mustache 1.1.1
3:  mustache (1.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mustache-1.1.1.gemspec
Using uri 0.12.0
3:  uri (0.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uri-0.12.0.gemspec
Using nio4r 2.5.8
3:  nio4r (2.5.8) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/nio4r-2.5.8.gemspec
Using version_gem 1.1.1
3:  version_gem (1.1.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/version_gem-1.1.1.gemspec
Using oj 3.13.14
3:  oj (3.13.14) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oj-3.13.14.gemspec
Using optimist 3.0.1
3:  optimist (3.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/optimist-3.0.1.gemspec
Using pg 1.4.5
3:  pg (1.4.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pg-1.4.5.gemspec
Using r2 0.2.7
3:  r2 (0.2.7) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/r2-0.2.7.gemspec
Using raindrops 0.20.0
3:  raindrops (0.20.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/raindrops-0.20.0.gemspec
Using rchardet 1.8.0
3:  rchardet (1.8.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rchardet-1.8.0.gemspec
Using rexml 3.2.5
3:  rexml (3.2.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rexml-3.2.5.gemspec
Using rinku 2.0.6
3:  rinku (2.0.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rinku-2.0.6.gemspec
Using rotp 6.2.2
3:  rotp (6.2.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rotp-6.2.2.gemspec
Using rqrcode_core 1.2.0
3:  rqrcode_core (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode_core-1.2.0.gemspec
Using rubyzip 2.3.2
3:  rubyzip (2.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rubyzip-2.3.2.gemspec
Using tilt 2.0.11
3:  tilt (2.0.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tilt-2.0.11.gemspec
Using sshkey 2.0.0
3:  sshkey (2.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sshkey-2.0.0.gemspec
Using stackprof 0.2.23
3:  stackprof (0.2.23) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/stackprof-0.2.23.gemspec
Using unf_ext 0.0.8.2
3:  unf_ext (0.0.8.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf_ext-0.0.8.2.gemspec
Fetching webrick 1.7.0
Installing webrick 1.7.0
3:  webrick (1.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/webrick-1.7.0.gemspec
Using xorcist 1.1.3
3:  xorcist (1.1.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/xorcist-1.1.3.gemspec
Using i18n 1.12.0
3:  i18n (1.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/i18n-1.12.0.gemspec
Using tzinfo 2.0.5
3:  tzinfo (2.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/tzinfo-2.0.5.gemspec
Using mail 2.8.0.edge from https://github.com/discourse/mail.git (at main@5b700fc)
3:  mail (2.8.0.edge) from /var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/mail-5b700fc95ee6/mail.gemspec
Using net-protocol 0.2.1
3:  net-protocol (0.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-protocol-0.2.1.gemspec
Using addressable 2.8.1
3:  addressable (2.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/addressable-2.8.1.gemspec
Using aws-sigv4 1.5.0
3:  aws-sigv4 (1.5.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sigv4-1.5.0.gemspec
Using bootsnap 1.15.0
3:  bootsnap (1.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/bootsnap-1.15.0.gemspec
Using rack-test 2.0.2
3:  rack-test (2.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-test-2.0.2.gemspec
Using ecma-re-validator 0.4.0
3:  ecma-re-validator (0.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ecma-re-validator-0.4.0.gemspec
Using request_store 1.5.1
3:  request_store (1.5.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/request_store-1.5.1.gemspec
Using message_bus 4.3.0
3:  message_bus (4.3.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/message_bus-4.3.0.gemspec
Using rack-mini-profiler 3.0.0
3:  rack-mini-profiler (3.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-mini-profiler-3.0.0.gemspec
Using rack-protection 3.0.5
3:  rack-protection (3.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rack-protection-3.0.5.gemspec
Using sprockets 3.7.2
3:  sprockets (3.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sprockets-3.7.2.gemspec
Using uglifier 4.2.0
3:  uglifier (4.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/uglifier-4.2.0.gemspec
Using faraday 2.7.2
3:  faraday (2.7.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-2.7.2.gemspec
Using mini_suffix 0.3.3
3:  mini_suffix (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_suffix-0.3.3.gemspec
Using omniauth 1.9.2
3:  omniauth (1.9.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-1.9.2.gemspec
Using sassc 2.0.1
3:  sassc (2.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-2.0.1.gemspec
Using image_optim 0.31.2
3:  image_optim (0.31.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/image_optim-0.31.2.gemspec
Using mini_racer 0.6.3
3:  mini_racer (0.6.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_racer-0.6.3.gemspec
Using logstash-logger 0.26.1
3:  logstash-logger (0.26.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/logstash-logger-0.26.1.gemspec
Using sidekiq 6.5.8
3:  sidekiq (6.5.8) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sidekiq-6.5.8.gemspec
Using net-http 0.3.2
3:  net-http (0.3.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-http-0.3.2.gemspec
Using oauth-tty 1.0.5
3:  oauth-tty (1.0.5) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth-tty-1.0.5.gemspec
Using snaky_hash 2.0.1
3:  snaky_hash (2.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/snaky_hash-2.0.1.gemspec
Using pry 0.14.1
3:  pry (0.14.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-0.14.1.gemspec
Fetching puma 6.0.2
Installing puma 6.0.2 with native extensions
2:  cgi (0.3.6) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cgi-0.3.6.gemspec
Using rbtrace 0.4.14
2:  rbtrace (0.4.14) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rbtrace-0.4.14.gemspec
Using redis-namespace 1.9.0
2:  redis-namespace (1.9.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/redis-namespace-1.9.0.gemspec
Using rqrcode 2.1.2
2:  rqrcode (2.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rqrcode-2.1.2.gemspec
Using rss 0.2.9
2:  rss (0.2.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rss-0.2.9.gemspec
Using unf 0.1.4
2:  unf (0.1.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unf-0.1.4.gemspec
Using unicorn 6.1.0
2:  unicorn (6.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/unicorn-6.1.0.gemspec
Using activesupport 7.0.3.1
2:  activesupport (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activesupport-7.0.3.1.gemspec
Using net-imap 0.3.1
2:  net-imap (0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-imap-0.3.1.gemspec
Using net-pop 0.1.2
2:  net-pop (0.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-pop-0.1.2.gemspec
Using net-smtp 0.3.3
2:  net-smtp (0.3.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/net-smtp-0.3.3.gemspec
Fetching css_parser 1.13.0
Installing css_parser 1.13.0
2:  css_parser (1.13.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/css_parser-1.13.0.gemspec
Using aws-sdk-core 3.130.2
2:  aws-sdk-core (3.130.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-core-3.130.2.gemspec
Using json_schemer 0.2.23
2:  json_schemer (0.2.23) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/json_schemer-0.2.23.gemspec
Using faraday-retry 2.0.0
2:  faraday-retry (2.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/faraday-retry-2.0.0.gemspec
Using oauth2 1.4.11
2:  oauth2 (1.4.11) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth2-1.4.11.gemspec
Using mini_scheduler 0.15.0
2:  mini_scheduler (0.15.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/mini_scheduler-0.15.0.gemspec
Using oauth 1.1.0
2:  oauth (1.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/oauth-1.1.0.gemspec
Using pry-byebug 3.10.1
2:  pry-byebug (3.10.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-byebug-3.10.1.gemspec
Using pry-rails 0.3.9
2:  pry-rails (0.3.9) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/pry-rails-0.3.9.gemspec
Using globalid 1.0.0
2:  globalid (1.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/globalid-1.0.0.gemspec
Using activemodel 7.0.3.1
2:  activemodel (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activemodel-7.0.3.1.gemspec
Using aws-sdk-kms 1.56.0
2:  aws-sdk-kms (1.56.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-kms-1.56.0.gemspec
Using aws-sdk-sns 1.53.0
2:  aws-sdk-sns (1.53.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-sns-1.53.0.gemspec
Using omniauth-oauth2 1.7.3
2:  omniauth-oauth2 (1.7.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth2-1.7.3.gemspec
Using omniauth-oauth 1.2.0
2:  omniauth-oauth (1.2.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-oauth-1.2.0.gemspec
Using activejob 7.0.3.1
2:  activejob (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activejob-7.0.3.1.gemspec
Using active_model_serializers 0.8.4
2:  active_model_serializers (0.8.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/active_model_serializers-0.8.4.gemspec
Using activerecord 7.0.3.1
2:  activerecord (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/activerecord-7.0.3.1.gemspec
Using aws-sdk-s3 1.114.0
2:  aws-sdk-s3 (1.114.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/aws-sdk-s3-1.114.0.gemspec
Using omniauth-facebook 9.0.0
2:  omniauth-facebook (9.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-facebook-9.0.0.gemspec
Using omniauth-github 1.4.0
2:  omniauth-github (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-github-1.4.0.gemspec
Using omniauth-google-oauth2 0.8.2
2:  omniauth-google-oauth2 (0.8.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-google-oauth2-0.8.2.gemspec
Using omniauth-twitter 1.4.0
2:  omniauth-twitter (1.4.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/omniauth-twitter-1.4.0.gemspec
Using discourse-seed-fu 2.3.12
2:  discourse-seed-fu (2.3.12) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/discourse-seed-fu-2.3.12.gemspec
1:  racc (1.6.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/racc-1.6.2.gemspec
Using nokogiri 1.13.10 (x86_64-linux)
2:  nokogiri (1.13.10) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/nokogiri-1.13.10-x86_64-linux.gemspec
Using loofah 2.19.1
2:  loofah (2.19.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/loofah-2.19.1.gemspec
Using rails-dom-testing 2.0.3
1:  rails-dom-testing (2.0.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-dom-testing-2.0.3.gemspec
Using ruby-readability 0.7.0
2:  ruby-readability (0.7.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/ruby-readability-0.7.0.gemspec
Using sanitize 6.0.0
Using rails-html-sanitizer 1.4.4
2:  rails-html-sanitizer (1.4.4) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails-html-sanitizer-1.4.4.gemspec
1:  sanitize (6.0.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sanitize-6.0.0.gemspec
Using actionview 7.0.3.1
1:  actionview (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview-7.0.3.1.gemspec
Using actionview_precompiler 0.2.3
2:  actionview_precompiler (0.2.3) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionview_precompiler-0.2.3.gemspec
Using actionpack 7.0.3.1
1:  actionpack (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionpack-7.0.3.1.gemspec
Using railties 7.0.3.1
2:  railties (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/railties-7.0.3.1.gemspec
Using actionmailer 7.0.3.1
1:  actionmailer (7.0.3.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/actionmailer-7.0.3.1.gemspec
Using sprockets-rails 3.4.2
2:  sprockets-rails (3.4.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sprockets-rails-3.4.2.gemspec
Using lograge 0.12.0
1:  lograge (0.12.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/lograge-0.12.0.gemspec
Using rails_failover 0.8.1
2:  rails_failover (0.8.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_failover-0.8.1.gemspec
Using rails_multisite 4.0.1
1:  rails_multisite (4.0.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/rails_multisite-4.0.1.gemspec
Using sassc-rails 2.1.2
1:  sassc-rails (2.1.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/sassc-rails-2.1.2.gemspec
3:  puma (6.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/puma-6.0.2.gemspec
0:  openssl (3.0.2) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-3.0.2.gemspec
Using web-push 2.1.0 from https://github.com/xfalcox/web-push (at openssl-3-compat@369df8f)
Using openssl-signature_algorithm 1.2.1
1:  web-push (2.1.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/bundler/gems/web-push-369df8f475a4/web-push.gemspec
2:  openssl-signature_algorithm (1.2.1) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/openssl-signature_algorithm-1.2.1.gemspec
Using cose 1.3.0
3:  cose (1.3.0) from /var/www/discourse/vendor/bundle/ruby/3.1.0/specifications/cose-1.3.0.gemspec
Bundle complete! 133 Gemfile dependencies, 171 gems now installed.
Gems in the groups 'test' and 'development' were not installed.
Bundled gems are installed into `./vendor/bundle`
We need the full rebuild logs for that, looks like you cut the last part
I´ve attached my full rebuild log
out.txt (3.5 KB)
Please share your app.yml file
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.socketed.template.yml"
#  - "templates/sshd.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
#  - "80:80"   # http
#  - "443:443" # https
   - "4001:22"
params:
  db_shared_buffers: "4096MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  DISCOURSE_DEFAULT_LOCALE: de
  UNICORN_WORKERS: 8
  DISCOURSE_HOSTNAME: forum.xy.at
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'noreply@xy.at'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_AUTHENTICATION: login
  DISCOURSE_SMTP_ADDRESS: mail.xy.at
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
  DISCOURSE_SMTP_USER_NAME: forum@xy.at
  DISCOURSE_SMTP_PASSWORD: "xxx"
  DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          #- git clone https://github.com/angusmcleod/discourse-quick-messages
          - git clone https://github.com/discourse/discourse-solved
          #- git clone https://github.com/angusmcleod/discourse-locations
          - git clone https://github.com/paviliondev/discourse-layouts.git
          - git clone https://github.com/discourse/discourse-signatures.git
run:
