Hi all,
When attempting an upgrade from 2.5.0beta2 to 2.5.0.beta3 via ./launcher rebuild app on the command line I keep running into rubygem timeouts at
cd /var/www/discourse && gem update bundler
that cause the rebuild to fail.. has anyone else encountered the same? Sometimes it times out on the rubygems.org/specs.4.8.gz file and sometimes it has timeouts on specific packages. Previous upgrades used to work seamlessly on this particular instance. Any ideas on how to fix this? I’m ready to try a fresh install off a backup otherwise..
I, [2020-04-26T00:37:59.817638 #1] INFO -- : > cd /var/www/discourse && gem update bundler
ERROR: While executing gem ... (Gem::RemoteFetcher::UnknownHostError)
timed out (https://rubygems.org/specs.4.8.gz)
167:signal-handler (1587861540) Received SIGTERM scheduling shutdown...
I, [2020-04-26T00:39:00.334060 #1] INFO -- :
I, [2020-04-26T00:39:00.334828 #1] INFO -- : Terminating async processes
I, [2020-04-26T00:39:00.335004 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/10/bin/postmaster -D /etc/postgresql/10/
main pid: 50
I, [2020-04-26T00:39:00.335154 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 167
2020-04-26 00:39:00.335 UTC [50] LOG: received fast shutdown request
167:M 26 Apr 2020 00:39:00.351 # User requested shutdown...
167:M 26 Apr 2020 00:39:00.351 * Saving the final RDB snapshot before exiting.
2020-04-26 00:39:00.360 UTC [50] LOG: aborting any active transactions
2020-04-26 00:39:00.362 UTC [50] LOG: worker process: logical replication launcher (PID 59) exited with exit code 1
2020-04-26 00:39:00.365 UTC [54] LOG: shutting down
167:M 26 Apr 2020 00:39:00.616 * DB saved on disk
167:M 26 Apr 2020 00:39:00.616 # Redis is now ready to exit, bye bye...
2020-04-26 00:39:00.747 UTC [50] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && gem update bundler failed with return #<Process::Status: pid 307 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"web", "cmd"=>["gem update bundler", "find $home ! -user discourse -exec chown discourse {} \\+"]}
7b53e40ff232069b5b0ac1355c706d777536284eece872cb7cfe46647561aa9b
