Update failing due to rate limiting by RubyGems
Users are experiencing build failures due to RubyGems rate limiting, receiving HTTP 429 errors when running bundle install during Discourse updates. The issue appears to be triggered by high request rates from the Discourse bootstrap script, possibly exacerbated by plugins like discourse-backups-to-dropbox. While some users suggest the problem may be related to outdated bundler versions, others note that the rate limit is enforced at 10 requests per second, with potential exceptions for CDN-cached endpoints. The community discusses the need to contact RubyGems directly for resolution, as the Discourse team cannot reproduce the issue or provide diagnostic data. One user found a workaround by increasing swap space, while others recommend checking for plugin-related issues or updating bundler. The official RubyGems response indicates the problem may stem from older bundler versions sending excessive requests. hnaseri, mpalmer, robbyoconnor, pfaffman, dmitry_fedyuk, thabbs, codinghorror, watchmanmonitor, djensen47, parisa, sam, zogstrip
Hello. I wanted to update my discourse for new commits, it did fail. Then I rebuild app, it also failed with the following error. Any Idea?
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 13406 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
1202bf591b3bb66f4bb14db9ffd2761171eaaece447b8e3c00051fd4866d511c
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
What’s the actual error? “please scroll up and look for earlier error messages”
I dont know its a lot of text. I searched for “error” and these are the lines I got:
HTTP 429 Too Many Requests https://index.rubygems.org/info/sprockets-rails
Bundler::HTTPError: Net::HTTPTooManyRequests: <html>
<head><title>429 Too Many Requests</title></head>
I, [2017-06-16T21:36:48.032740 #14]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
rake aborted!
Gem::MissingSpecError: Could not find 'http-cookie' (~> 1.0) among 248 total gem(s)
Checked in 'GEM_PATH=/var/www/discourse/vendor/bundle/ruby/2.4.0', execute `gem env` for more information
You’re getting throttled by rubygems. Are you running on AWS? What does your pups template look like?
Read more here: RubyGems.org API - RubyGems Guides
I got this rebuilding last week. I commented out a plugin. I built again. It worked. Then I couldn’t figure out why that plugin could have caused a problem, put it back in, rebuilt, and it worked. I had prepared a bug report plea for help, but since the problem went away, I never posted it.
There have been a handful of these “too many requests” errors from rubygems lately. I can’t make sense of them.
No. I’m not on AWS. I have a local server. [quote=“robbyoconnor, post:4, topic:64636”]
[/quote]
I don’t know what is pups template. could you explain?
So I commented out two plugins but it didn’t help. now I commented even more. Hope it would work this time.
Now I’m getting this error :confused:
Removing old container
+ /usr/bin/docker rm app
Error response from daemon: Driver overlay failed to remove root filesystem abd13a925ecc025fb672e6ee0e594758f846f3ed393a8f647bb6cf1cf970fa6b: remove /var/lib/docker/overlay/d6866837ea0650d91bb09d012158ca82276cecc6d2c1c332d31e18c0651845dc/merged: device or resource busy
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: Container is marked for removal and cannot be started.
Error: failed to start containers: app
what is this?
I rebooted my server as the last resort :joy: and rebuild app and now it was rebuilded without error.
Then I added the plugins I’ve removed, However I got the same error I reported earlier again. So could it be one of the plugins that causes error?
I’m not sure why it would…somehow you’re hitting the rubygems rate limit threshold.
Is there any thing I could do to find the culprit?
I’m not entirely sure – but what are you hosted?
Digital Ocean. At about the same time, I did similar rebuilds at Digital Ocean (and I’m pretty sure, the same data center).
I’m not entirely sure – A lot of people have had this issue – I’ve never encountered this issue…
Odd…what plugin caused it? Look at its Gemfile maybe?
The plugins I removed that got it fixed with a server reboot was these:
      - git clone http://github.com/[Communiteq](https://www.communiteq.com) (formerly DiscourseHosting)/discourse-sitemap.git
      - git clone https://github.com/xfalcox/discourse-backups-to-dropbox.git
I added them back and it failed again.
Of those discourse-sitemap is the more likely culprit.
Ok so I remove this and add all others to see what happens. However I dont know why it is the culprit? It has not been updated for a long time.
Plugins get broken if Discourse gets updated in a way that breaks the plugin. The other plugin you listed is maintained by a team member, so it’s somewhat more likely he’ll notice something’s wrong before other people.
Nope. It failed again. So I’m removing backup to dropbox this time.
But even if it is a broken plugin, why it would trigger rubbygem threshold? Its not making sense.
I couldn’t figure that out either. I suspect that it’s unrelated.
Are you still getting the rubygem error?
