Der Scrollbalken springt beim Öffnen des Admin-panels nicht nach oben
Hi.
When I’m on a topic on which I have scrolled down (even just a bit), like this:
And I go the admin panel, the admin opens like this:
Which forces me to scroll up in order to actually see the admin tabs.
This is a bit annoying and it would be better if the scrollbar went automatically up when we enter the admin panel.
6 „Gefällt mir“
@Osama can you add to your list.
Repro is:
  1. reload this topic
  2. scroll down
  3. click admin from menu
  4. it is positioned correctly
  5. click back
  6. scroll down
  7. click admin from menu
  8. it is not positioned right
You can hold off on fixing this for 24 hours or so in case @eviltrout has any ideas here cause ember should really have our back here.
4 „Gefällt mir“
Fixed in:
https://github.com/discourse/discourse/pull/6039
5 „Gefällt mir“
This topic was automatically closed after 28 hours. New replies are no longer allowed.
