Search feedback for 2 character searches
The discussion revolves around the search functionality on the forum, specifically when searching for terms with fewer than three characters. lisajill reported an issue where searching for “go” resulted in no feedback or results, suggesting that a minimum character requirement should be communicated to the user. codinghorror disagreed, providing examples of successful searches for “go” and “gox” with a loading spinner and “no results found” message. However, lisajill argued that the lack of feedback for searches with fewer than three characters is confusing and proposed displaying a message, such as “you’ll need at least 3 characters to search.”
Other users, including cpradio, suggested alternative solutions, such as a placeholder inside the search box indicating the minimum character requirement. cpradio and vulkanino proposed visual examples of how this could be implemented. lisajill and Barbie expressed support for providing more feedback to the user. benmcginnes suggested an exception for shorter words, using regex to indicate the end of the word.
Good morning! We had a report that a user searched for “go” and could not find anything. Or rather, that the search did not work.
Now, I’m used to forums with a 3 character minimum for search; but maybe not everyone is. I suspect that is what is going on here; however, as part of the bigger picture, I’d like to request some error reporting when the search is not going to function. Right now on these forums try searching for “go” - nothing at all happens. It’d be more user friendly if the search reported why that was (not) happening.
In fact, I’m only guessing at the “why” here. A UI element that does not respond in any way is a wee bit confusing. :slight_smile:
Hmm, not sure I agree with this. Here’s me searching for go
Here’s me searching for gox
Note appearance of search “I’m doin’ stuff” spinner, and results (in this case “no results found”). So I think the feedback is fairly clear here.
Just to provide a bit more feedback. We’ve actually had that same question appear on our instance, but I wouldn’t say it appear enough times for us to report it (yet). I’m personally torn on it. I think adding more would clutter the search, unless it can be done as a “placeholder” inside the search box, such as “type X or more characters”
1 „Gefällt mir“
Your second example for ‘gox’ is what I’d expect if there are no results for any reason.
Otherwise it just looks like “nothing happened what’s going on?” - how about some user feedback so the user knows what’s going on? Putting in “go” and getting no response from the interactive box is pretty confusing. The second example is much, much less confusing.
For the “go” search why not tell the user, “you’ll need at least 3 characters to search” instead remaining dormant?
Would this be enough?
5 „Gefällt mir“
@cpradio - I don’t know that would be enough for everyone; but it’d make me pretty darn happy. :slight_smile: At least we’re giving users some info to work with.
2 „Gefällt mir“
I like this! I have tried searching 2 characters… Eventually figured out I need more but it was frustrating when I was first learning to use forum software.
1 „Gefällt mir“
This?
I like that @vulkanino; especially if it were in combination with @cpradio’s labeling warning the user up front.
Perhaps, if a minimum exists or is configured that way, to include an exception for shorter words where it is explicitly that two letter word. So something like regex to indicate the end of the word (I’m thinking go$ except that’s normally the end of a line and might not work exactly). That should satisfy the obscure programmers and the strategy board gamers.
