Sujan
(Jan P.)
13 december 2017 om 18:09
1
This post includes the URL http://example.org/path#anchor
(The Google search result work as a valid fallback, but it would be still better if Discourse could return these posts) .
I don’t think URL searching is supported at the current time, so this would be a feature request. The domain name is probably tokenized like language words. Is URL searching something postgres has support for @sam ?
Note that using quotes does work, though
sam
(Sam Saffron)
14 december 2017 om 00:30
3
Something is definitely off here cause that string should be tokenized.
sam
(Sam Saffron)
19 december 2017 om 05:05
5
Nice bug report, this is fixed per:
committed 05:04AM - 19 Dec 17 UTC
Previously we used to break up words with dots incorrectly leading to
missing se… arch terms
Requires a re-index on broken posts (which you can do by editing)
sam
(Sam Saffron)
gesloten
20 december 2017 om 07:00
6
This topic was automatically closed after 25 hours. New replies are no longer allowed.
