רואה את כל ההודעות המוצמדות?
Is there an easy way to search for pinned posts in a category or the whole forum, if I’ve unpinned them for myself? I’ve just been reminded that I probably should update some of them and finding them was proving a little bit tricky. Now that I’ve wrote this I’ve realised I could just look at the forum in a private window logged out to see them all, but is there an easier way if you’re logged in?
You can search for in:pinned. You can also search for a category and pinned topics.
https://meta.discourse.org/search?context=topic&context_id=235848&q=in%3Apinned%20order%3Alatest&skip_context=true
You can also choose the filter in advanced search. It’s in the dropdown below “are read”.
