This is a how-to guide for setting up environmental variables in a self-hosted Discourse installation.
Required user level: Administrator
Environmental variables play a crucial role in configuring your Discourse instance. They can store sensitive data like API keys and database passwords, making your installation more secure and flexible. In Discourse, environmental variables are set in the app.yml file within your Docker container setup.
Adding environmental variables to a .yml (YAML) file is straightforward. Here’s a basic example:
# This is a YAML file with environmental variables
env:
VARIABLE_NAME: "Variable Value"
ANOTHER_VARIABLE: "Another Value"
In the context of a Discourse Docker container, environmental variables are stored in the env section of your app.yml file.
Here's an example of an app.yml file:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you must rebuild
templates:
#- "templates/web.ssl.template.yml"
#- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "80:80" # http
- "443:443" # https
params:
db_shared_buffers: "256MB"
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 3
DISCOURSE_HOSTNAME: 'discourse.example.com'
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'user@example.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
DISCOURSE_SMTP_ADDRESS: smtp.example.com # (mandatory)
DISCOURSE_SMTP_PORT: 587 # (optional)
DISCOURSE_SMTP_USER_NAME: user@example.com # (optional)
DISCOURSE_SMTP_PASSWORD: a_s3cr3t_p@ssword # (optional)
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
#LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## The CDN address for this Discourse instance (configured to pull)
#DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
Let’s get started with adding environmental variables to your site! ![]()
The following instructions are written for a Standard Discourse Installation
Login to Your Server
Use a tool like PuTTY or the terminal on Unix-based systems to SSH into your server.
ssh username@your-server-ip
Navigate to the Discourse Directory
Once you have access to your server, navigate to the directory containing your Discourse Docker setup, this is typically located at /var/discourse.
cd /var/discourse
Open the app.yml File
You’ll need to open the app.yml file in a text editor. For this example we’ll be using nano.
nano containers/app.yml
Add Your Environmental Variables
In the app.yml file, you’ll find an env section. This is where you can add your environmental variables.
env:
For example, if you wanted to set the DISCOURSE_ENABLE_CORS environmental variable to true to enable Cross-Origin Resource Sharing (CORS), you would add the following line to the env section:
env:
DISCOURSE_ENABLE_CORS: "true"
The whitespace and formatting is important here, so make sure to maintain the correct indentation (two spaces) for the new line
Once you’ve modified your variables, save and close the file.
Rebuild the Discourse Container
Finally, you’ll need to rebuild your Discourse Docker container for the changes to take effect. You can do this with the following command:
./launcher rebuild app
Alternatively, to update environmental variables for a running container without rebuilding, you can also use:
./launcher destroy app
./launcher start app
After the rebuild process completes, your updated environmental variables will be available to your Discourse application! ![]()
Check document
Perform check on document:
