Setting a persona for AI Helper "explain" causes error
I set the persona for the AI Helper’s “explain” feature to be a custom persona (using GPT-4.1-mini) and clicking explain causes it to load indefinitely. I switched it back to default and it started working again
Error log
Message (2 copies reported)
Job exception: no implicit conversion of nil into String
Backtrace
/var/www/discourse/plugins/discourse-ai/lib/ai_helper/assistant.rb:143:in block in generate_prompt' /var/www/discourse/plugins/discourse-ai/lib/personas/bot.rb:159:in block in reply’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:187:in block (3 levels) in perform_completion!' /var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:230:in block (5 levels) in perform_completion!’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:230:in each' /var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:230:in block (4 levels) in perform_completion!’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:221:in each' /var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:221:in block (3 levels) in perform_completion!’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:535:in call_block' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:526:in <<’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-protocol-0.2.2/lib/net/protocol.rb:168:in read' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:631:in read_chunked’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:595:in block in read_body_0' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:588:in inflater’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:593:in read_body_0' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:363:in read_body’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:216:in block (2 levels) in perform_completion!' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2433:in block in transport_request’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http/response.rb:320:in reading_body' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2430:in transport_request’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:2384:in request' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/net_patches.rb:19:in block in request_with_mini_profiler’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:50:in step' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rack-mini-profiler-3.3.1/lib/patches/net_patches.rb:18:in request_with_mini_profiler’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:158:in block in perform_completion!' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1632:in start’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/net-http-0.6.0/lib/net/http.rb:1070:in start' /var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:129:in perform_completion!’
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/open_ai.rb:53:in perform_completion!' /var/www/discourse/plugins/discourse-ai/lib/completions/llm.rb:374:in generate’
/var/www/discourse/plugins/discourse-ai/lib/personas/bot.rb:90:in reply' /var/www/discourse/plugins/discourse-ai/lib/ai_helper/assistant.rb:148:in generate_prompt’
/var/www/discourse/plugins/discourse-ai/lib/ai_helper/assistant.rb:197:in stream_prompt' /var/www/discourse/plugins/discourse-ai/app/jobs/regular/stream_post_helper.rb:30:in execute’
/var/www/discourse/app/jobs/base.rb:316:in block (2 levels) in perform' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management/null_instance.rb:49:in with_connection’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/rails_multisite-6.1.0/lib/rails_multisite/connection_management.rb:21:in with_connection' /var/www/discourse/app/jobs/base.rb:303:in block in perform’
/var/www/discourse/app/jobs/base.rb:299:in each' /var/www/discourse/app/jobs/base.rb:299:in perform’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:220:in execute_job' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:185:in block (4 levels) in process’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:180:in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse’
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in call' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse' /var/www/discourse/lib/sidekiq/pausable.rb:131:in call’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job/interrupt_handler.rb:9:in call' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:183:in block in traverse' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:26:in track’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/metrics/tracking.rb:134:in call' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:182:in traverse’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/middleware/chain.rb:173:in invoke' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:184:in block (3 levels) in process’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:145:in block (6 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:118:in local’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:144:in block (5 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/config.rb:39:in block in class:Config’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:139:in block (4 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:281:in stats’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:134:in block (3 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:15:in call’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:133:in block (2 levels) in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_retry.rb:85:in global’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:132:in block in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/job_logger.rb:40:in prepare’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:131:in dispatch' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:183:in block (2 levels) in process’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in handle_interrupt' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:182:in block in process’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in handle_interrupt' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:181:in process’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:86:in process_one' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/processor.rb:76:in run’
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:10:in watchdog' /var/www/discourse/vendor/bundle/ruby/3.3.0/gems/sidekiq-7.3.9/lib/sidekiq/component.rb:19:in block in safe_thread’
Fixed the bug here:
https://github.com/discourse/discourse-ai/pull/1433
