Setting up a cluster?
Hei folks,
I’d like to setup a cluster (two nodes running discourse) for high availibitly and load balancing.
How do setup such a cluster?
Thanks,
Jan
See the install docs at discourse/docs/INSTALL.md at main · discourse/discourse · GitHub which cover the advanced install. Basically you deploy multiple containers in the web role talking to a database container.
Hello,
thanks for your feedback. I read the manual before, but some thinks are not clear to me, yet :-/
  • If each cluster-node is running its own database - how are they supposed to be synched? Using Message Queuing, Postgres-Clustering or else?
  • What is the reason for using Docker here? How does the App-environment interactv with my Host System? How is resonsible for patching requirements?
Thanks, yanosz
Should I setup one shared redis for all web nodes, or setup multiply redis for each node separately ?
You need one central Redis. Redis isn’t (just) used as a cache for Discourse; it also acts as a message broker for all the MessageBus traffic, so if you had one Redis per node, things would get… weird. And broken.
