Setup discourse on Mac OS
I’m following standard guide to install discourse on my local mac.
After launching the setup tool ./discourse-setup I’ve got error message:
cd /pups && git pull && /pups/bin/pups --stdin /usr/local/bin/docker: Error response from daemon: Mounts denied: er.com/docker-for-mac/osxfs/#namespaces for more info. . r/discourse/shared/standalone/log/var-log are not shared from OS X and are not known to Docker. You can configure shared paths from Docker -> Preferences... -> File Sharing.
Initially I’ve tried to install to my work directory inside /Users
Then I installed to /var/discourse folder, the same error.
And then I tried to add /var folder to Docker’s Sharing Files and got message
The path /var is reserved by Docker
What am I missing here?
Discourse uses Docker when installing in production.
For local install to thinker with, use this guide:
Well, it seems to me there should be a quick fix, using docker is the pleasure and convenience.
Did you find the fix ? I am facing the same
No, I didn’t, have to work on remote host
whats the difference?
what if I consider localhost as the remote host ?
Edit:
I don’t get it, do I need two /var directory ?
the remote host is linux
So I won’t need a remote host if my parent host is linux right ?
This sounds silly, there should be some workaround.
Still I doubt if parent is a linux why wouldn’t docker say
Kind of misunderstanding, I’m ssh’ing to linux box, installed there docker and then discourse - that’s my development environment for now.
I am only talking about development machine, say I have a linux box, installed docker and discourse. How does it matter whether I access it remotely from some other machine or open that machine directly.
EDIT:
To add, In mac development environment I am able to create plugins and be able to run them from local server, why can’t I install it in development, why would I need a remote server to be able to install it.
EDIT2:
found this: for non docker install
bundle exec rake plugin:install repo=<repo url>
It might depend on version of OS X and/or docker, but on my machine /var is just a symlink to the real folder /private/var.
Changing the volume paths in containers/app.yml (or whatever your configuration file is) to something like:
volumes:
  • volume:
    host: /private/var/discourse/shared/web-only
    guest: /shared
  • volume:
    host: /private/var/discourse/shared/web-only/log/var-log
    guest: /var/log
did it for me.
