Should I set up a masked redirect to my Disclosure VPS? Is there an alternative?
JustJasper is seeking advice on integrating their Disclosure forum, hosted on an OVH VPS, with their existing Webflow website. They want to access the forum through ‘forum.mywebsite.com’ and considered a masked forward within Hover, but are concerned about the SEO implications.
Falco suggested a better alternative: creating an additional A DNS entry for ‘forum.mywebsite.com’ that points to the OVH IP. JustJasper found this solution to be easy and effective.
First of all, I should preface this with the fact that I am a newby when it comes to SSH and VPSs. That said, I have managed to get a Disclosure instance up and running on a OVH VPS over the course of the afternoon (including the e-mail sending! yay me!).
My question is how best to integrate the forum with my existing site? My website is hosted by Webflow, and therefore I have limited ability to edit or modify the native files. The domain where the website resides is managed by Hover (with a simple ‘A’ record map to the Webflow DNS. All working fine so far.
The issue, and resulting question, arises from how best to integrate the Disclosure forum, hosted on a VPS (with an obscure IP address), into that website?
Ideally, I’d want my visitors to be able to access the forum through ‘forum.mywebsite.com’, and (I think) I can accomplish this through a masked forward within Hover - however, I understand that masked-forwarding is considered SEO-unfriendly, and feels like a bit of a fudge? Is there a better alternative?
You should have an A DNS entry pointing to your webflow DNS site.
Add another A entry on forum.mywebsite.com pointing to the OVH IP.
Of course! That was an (almost annoyingly) easy fix!
Thanks a bunch.
