Sidekiq warnings
in a virtual server with 8GB RAM, i don’t suppose sidekiq using slightly more than 500M is an issue?
i’m interested whether to add the following line in my app.yml
env:
  UNICORN_SIDEKIQ_MEMORY_KILLER_MAX_RSS: 1024
Tot RAM doesn’t help here. It is kind of same thing than with amount of workers in the PHP-world and how much memory is allocated. Well, totally different thing, but yet :joy:
My experiances are saying that 500 is enough for totally fresh installs, when there isn’t practically any components and plugins in use, nor users. 550+ at least is needed.
my last rebuild worked, with 700 set for this
it’s strange that i’m still getting warning, the previous one / before the app.yml change was 0.1MB higher
In this other thread I see a different setting is mentioned
Sidekiq is consuming too much memory
But I also see an unresolved similar situation relatively recently in
Sidekiq is consuming too much memory even with UNICORN_SIDEKIQ_MAX_RSS adjusted
