Redis used_memory limited to 1024mb?
It seems like there is some limit preventing Redis from being able to use more than 1024mb?
I have noticed as soon as that amount is exceeded in the Sidekiq dashboard (MB RSS) is when I start getting logs like:
Your Redis network connection is performing extremely poorly. Last RTT readings were [96585, 101554, 97189, 99769, 94618], ideally these should be < 1000. Ensure Redis is running in the same AZ or dat
When I check using this:
./launcher enter app
redis-cli info memory
This is the result:
# Memory
used_memory:1072837696
used_memory_human:1023.14M
used_memory_rss:484577280
used_memory_rss_human:462.13M
maxmemory:0
maxmemory_human:0B
I set this in the app.yml:
UNICORN_SIDEKIQ_MAX_RSS: 8000
In the Sidekiq dashboard, there is 4,553 MB RSS being used and utilisation is 100%. This is with 2 UNICORN_SIDEKIQS with DISCOURSE_SIDEKIQ_WORKERS not being set (so the default of 5).
I was under the impression UNICORN_SIDEKIQ_MAX_RSS would allow redis to use more ram? I’m a bit lost, any guidance would be appreciated! :love_letter:
This is with Discourse 3.3.2 Stable.
Redis will only uses the memory it needs, the RTT errors are unrelated, they are more likely coming from an install being far away or a machine being out of juice to run Redis.
Thanks! I believe the RTT issues were because THP was still enabled, when I had thought otherwise:
