Hoping this is the right location to file this minor issue.
Whats the issue?: The invite code field is missing the required (*) mark.
Also as I’m reviewing the screenshot. If I might suggest, the description for Username, the first word isn’t using proper casing. I’d recommend “Unique, no spaces, short”. Password as well “At least 10 characters”.
Thank you.
Ah, nice catch. The UI should be consistent for all the fields.
