Slack (official plugin) sending topics from staff categories
Regarding:
  • I have the plugin setup. However it is sending topics and replies from staff categories into the designated Slack channel. This, obviously presents an issue regarding privilege - I doubt this is intentional, so is there a work-around ?
  • Also, regarding the setup docs on the repo page above:
  • after step 4 it states:
By default, every new post on your Discourse will now create a Slack message in the channel you specified..
  • … this should be changed to state that setting up the slash command is not optional as once this plugin is installed, web-hook setup and a new topic is created/replied - it doesn’t send to slack channel unless these instructions are followed, followed by entering the appropriate /command in the slack channel assigned:
    /discourse [watch|follow|mute|help|status] [category|all]
    watch – notify this channel for new topics and new replies
    follow – notify this channel for new topics
    mute – stop notifying this channel
    status – show current notification state and categories
    i.e. /discourse watch all
only then will new topics/replies be sent successfully to the slack channel.
@nick should answer more specifically, but I think the correct way to handle this, is to make sure the user Slack is posting on behalf of, is not a staff user?
This is the only way the plugin currently has built in. The plugin setting is “slack discourse username”
I think there is still an issue here.
When you do:
/discourse status
It (correctly) only displays categories that the slack_discourse_username can see:
Here are your available categories: a, b, c
But if you do
And then create a post in the staff category, it gets posted to the channel anyway.
Do you mean /discourse watch all command posting topics of categories which are unavailable?
Yep, that’s the problem.
I’m looking forward to encouraging more people to use the plugin in their own channels now that they can subscribe to particular tags, but concerned that this issue leaves the door open for people to access categories that staff on the site assume are private.
@vinothkannans after all your work to add tag support and better test coverage of the slack plugin, do you have thoughts on how best to address this issue?
I created a PR for this. I hope it will this fix issue completely. Can you please look at the code?
@vinothkannans and @tgxworld, from the comments on the PR, I’m having trouble understanding who is waiting for whom to make the next move.
As I told in PR I will do the needful soon.
Edit: @mcwumbly PR updated :thumbsup:
Thanks! this is now working great.
