Soepel scrollen naar boven op de startpagina
The Smooth Scroll Top on Homepage theme component, created by Don, enables smooth scrolling to the top of the homepage when the logo is clicked. This component includes customizable settings for mobile and desktop, as well as an optional fade animation. fbpbdmin asked if this feature slows down the scroll compared to directly jumping to the bottom.
Install this theme component
Hello :wave:
This theme component add the smooth scrolling behaviour when you refresh topic list by clicking to the logo on homepage.
It contains some setting where you can enable this function separately on mobile or desktop and you can also enable the a fade animation while it scrolling up.
curious,
comparing to jumping to bottom directly, does this slow down bit to the top ?
