[Solved] Discourse Rebuild Failed to Bootstrap
Hi, before sorry for my bad English. I search search and again search but not see any fix for this problem.
I use OVH 4 GB VPS and install on Discourse. Working great! But if i want to rebuild Discourse see this error;
Extra info: if i reset my VPS then Discourse working great. And again i want to rebuild Discourse see this error;
System:
Ubuntu 14.04 LTS x64
System load:
  System information as of Thu Jun 11 16:57:58 EEST 2015
  System load: 0.0                Memory usage: 2%   Processes:       107
  Usage of /:  11.0% of 47.17GB   Swap usage:   0%   Users logged in: 0
  Graph this data and manage this system at:
    https://landscape.canonical.com/
Problem:
FAILED
RuntimeError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::                                                               Status: pid 423 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:105:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deplo                                                               yment --verbose --without test --without development'", "su discourse -c 'bundle exec rake db:migrate'", "su discou                                                               rse -c 'bundle exec rake assets:precompile'"]}
d3373830790a702d911b561b005d279c5d149d91046cec48e2b78c7cfd7ba2d1
FAILED TO BOOTSTRAP
Full log:
https://gist.github.com/muhyal/5ece5ca19c6810cef60b
Docker version:
root@vps174448:/var/discourse# docker --version
Docker version 1.6.2, build 7c8fca2
App.yml file:
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## Make sure to obey YAML syntax! You can use this site to help check:
## http://www.yamllint.com/
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting by uncommenting the web.ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  - "templates/sshd.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "80:80"   # fwd host port 80   to container port 80 (http)
  - "2222:22" # fwd host port 2222 to container port 22 (ssh)
params:
  ## On 1GB installs set to 128MB (to leave room for other processes)
  ## on a 4GB instance you may raise to 1GB
  db_shared_buffers: "1024MB"
  ## Set higher on large instances it defaults to 10MB, for a 3GB install 40MB is a good default
  ## this improves sorting performance, but adds memory usage per-connection
  db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  DISCOURSE_DEFAULT_LOCALE: tr
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  UNICORN_WORKERS: 4
  DISCOURSE_DEVELOPER_EMAILS: 'hidden'
  DISCOURSE_HOSTNAME: 'www.sitename.com'
  ## TODO: The mailserver this Discourse instance will use
  DISCOURSE_SMTP_ADDRESS: hidden
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: hidden
  DISCOURSE_SMTP_PASSWORD: hidden
  DISCOURSE_SMTP_ENABLE_START_TLS: true
  DISCOURSE_SMTP_OPENSSL_VERIFY_MODE: none
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discourse
## http://discourse.example.com/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-spoiler-alert.git
          - git clone https://github.com/discourse/discourse-tagging.git
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  #- exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'RAW_PASSWORD')" root
  ## If you want to authorized additional users, uncomment and change:
  #- exec: ssh-import-id username
  #- exec: ssh-import-id anotherusername
  - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
I18n::InvalidLocale: “tr” is not a valid locale
You should use tr_TR instead.
How do I skip this section @zogstrip thanks.
Skip this section?
You just need to change this line in you app.yml file
DISCOURSE_DEFAULT_LOCALE: tr_TR
I already change and works fine @zogstrip . Thanks again. Sorry for my bad English. I write a wrong reply.
