Solved Topic Badge
The Solved Topic Badge theme component, created by Don, enhances topic styling by adding customizable badges and background colors for solved and unsolved topics. It supports various placements (before/after title, inline) and allows users to adjust icons, text, and colors. The component has been updated to work with Glimmer topic lists and addresses compatibility issues with other plugins like discourse-umbrella-groupswitchdisplay. Users have reported and resolved bugs, including visual regressions in Discourse 3.5.0.beta8-dev where solved topics lost their green background due to changes in visited topic styling. A CSS fix was provided to restore the background color, and updates were made to ensure compatibility with core changes. Discussions also cover potential improvements, such as integrating the badge into topic status and removing legacy code. Don, Heliosurge, barto_95, Arkshine, ozkn, xkhalid, Moin, jordan.vidrine, digitaldominica, and Hyteller contributed to the discussion.
Install this theme component
Hello :waving_hand:
This theme component adds styling options to the solved and unsolved topics. You can set custom badge and background color.
By default it looks like this on topic list page :arrow_down_small:
Styled (before title)
With background
Inline
Styled (after title)
Topic title, Topic header
Styled
Screenshot 2023-10-11 at 23.40.35
Inline
Screenshot 2023-10-11 at 23.43.39
There are a bunch of settings where you can change the icon, text and style separately solved and unsolved.
Global indicator settings :arrow_down_small:
type
– styled (badge)
– inline (it placed inline before title)
placement (styled)
– before-title
– after-title
border-radius
– badge rounding
Solved Indicator settings
solved indicator
– It uses unicode :check_mark: but you can use other too. (e.g. emoji). It place before label.
solved border color
The badge has a 1px transparent border and this setting you can set a color for it.
enable solved topic background
Enabling this setting will activate the background field below it where you can set the topic list item background color.
Unsolved Indicator setting
Same settings for unsolved indicator below these…
If you want to enable the unsolved indicator than turn on the empty box on unsolved Discourse Solved plugin setting.
Todo:
– Try to move it to use as topic status (will appear everywhere the topic status is appear and it allows to use custom icon too)
Cool theme-component. Only one minor issue is the about category post also marked unsolved .
Hello @Heliosurge :wave:
Thank you :slight_smile:
Technically the about topic is also a solvable topic. If you have enabled the empty box on unsolved setting on Discourse Solved plugin then the empty box is appears for the topic list about topic and in the about topic too. To hide the unsolved badge for a specific topic you have to close it.
Awesome thank you! Learned something new.
:clinking_beer_mugs::smiling_face_with_sunglasses::+1::sparkles:
Thank’s for component….
but with the component
https://github.com/VaperinaDEV/discourse-solved-quote-
the message résolve not show with green, component don’t work …. :frowning:
it’s not possible to have 2 component one for subject and one for message work
Hello @barto_95 :waving_hand:
These two components should works together correctly but the correct component url is: GitHub - VaperinaDEV/discourse-solved-quote-customization · GitHub
Hello :waving_hand: I’ve updated this theme component to work with Glimmer topic list. :slightly_smiling_face: Thanks for the report: Discourse topic-list changes · Issue #4 · VaperinaDEV/solved-topic-badge · GitHub
The legacy topic list has been dropped this month.
The code can be removed:
Made a quick PR:
https://github.com/VaperinaDEV/solved-topic-badge/pull/6
Oops, sorry, I forgot to update this component. Thanks @Arkshine, I’ve merged it. :heart:
@ozkn, please update the component.
This component is incompatible with discourse-umbrella-groupswitchdisplay and cannot be used together. An error has occurred which may prevent your site from working correctly.
Reason: Conflict between active themes/components.
Click here to update, reconfigure, or disable the component.
(This message is only visible to site administrators.)
Thanks for the update. I updated and tried but I get the same error. @Don
Oh, yeah sorry I see. Fixed here: FIX: Discourse version to beta3 · VaperinaDEV/solved-topic-badge@e5889a3 · GitHub Please update again. :slight_smile:
Thanks, it’s working fine now without any problems.
Oops, sorry!
Hi Guys,
After updating to the latest version:
3.5.0.beta8-dev (commit: 5eca6d826e)
I encountered a visual regression related to the Discourse Solved and Solved Topic Badge plugins.
Issue:
Previously, solved topics would have a green background, and unsolved topics (awaiting solution) would appear with a red background in the topic list.
Now, all solved topics no longer display the green background, even though the setting is enabled.
Details:
Screenshot (after the update):
Expected:
Solved topics should retain the green background for better visual clarity.
Please let me know if this is a regression or if any new CSS changes are required to restore this behavior.
I think this happens on topics you have read because of the changes in
UX: Variable additions (#33473) · discourse/discourse@20f57ae · GitHub,
which added a separate background color for visited topics.
You could probably fix that with your own CSS until the theme component is adapted, but I can’t check how right now.
Issues with components that aren’t official should generally be reported in the topic.
Thanks Moin!
I managed to fix it using custom CSS:
.topic-list-item.solved,
.topic-list-item.visited.solved,
.latest-topic-list-item.solved,
.latest-topic-list-item.visited.solved {
  background-color: var(--success-low) !important;
CC: @sam @j.jaffeux
@Don due to recent variable additions to core, you may need to tweak your component a bit for the background colors to work, even when a topic has been visited.
Hello :waving_hand: Thanks for the report! Here is the update: UX: Adds background color for visited topic list items · VaperinaDEV/solved-topic-badge@1f87fe4 · GitHub
Hi @Don I noticed the colored background for logged out users do not get displayed.
And the background color for aside.quote.accepted-answer>blockquote doesn’t take the color of the solved badge is there a way to adjust it?
