Something seems to have gone wrong with my update
User peternlewis is experiencing issues with their Discourse update to 1.7.x. They are getting errors and nothing is showing up. codinghorror suggests trying safe mode, but peternlewis reports that it doesn’t work.
codinghorror recommends rebuilding the app from the command line, which peternlewis attempts, but encounters an error related to PostgreSQL. codinghorror advises removing third-party plugins and trying again.
peternlewis disables the solved and tags plugins, but still encounters issues. codinghorror suggests adding a Git pull before rebuilding, but peternlewis is already up-to-date.
peternlewis wonders if they should enter the Docker container and try updating, and peternlewis questions the PostgreSQL version discrepancy.
codinghorror explains that the Docker image was updated to PostgreSQL 9.5 in 2016. peternlewis finds that their app.yml was still set to PostgreSQL 9.3, updates it, and successfully rebuilds the app.
Something seems to have failed with my update to 1.7.x (https://forum.keyboardmaestro.com/).
Nothing is showing up and I’m getting errors like:
I’m wondering if the update failed part way through.
Any suggestions on how to get it going again?
Have you tried safe mode? Any incompatible plugins can break you.
No safe-mode does not do any better. It asks me if I want safe mode and I say yes I still get the same result. Nothing shows up at all
Try rebuilding again from the command line. If you are using any third party plugins, remove them before rebuilding.
Would that be:
cd /var/discourse
./launcher rebuild app
Will that update any files if they are not up to date?
Yes, give that a shot, but be sure to remove any third party plugins from the app.yml first.
I disabled solved and tags
#          - git clone https://github.com/discourse/discourse-tagging.git
#          - git clone https://github.com/discourse/discourse-solved.git
but I get this error when rebuilding:
root@forum:/var/discourse# ./launcher rebuild app
Fetching origin
Launcher is up-to-date
Stopping old container
+ /usr/bin/docker stop -t 10 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up-to-date.
I, [2017-01-18T09:41:34.458117 #13]  INFO -- : Loading --stdin
I, [2017-01-18T09:41:34.466939 #13]  INFO -- : > echo cron is now included in base image, remove from templates
I, [2017-01-18T09:41:34.470539 #13]  INFO -- : cron is now included in base image, remove from templates
I, [2017-01-18T09:41:34.470814 #13]  INFO -- : > apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5
E: Sub-process /usr/bin/dpkg returned an error code (1)
I, [2017-01-18T09:41:37.110594 #13]  INFO -- : Reading package lists...
Building dependency tree...
Reading state information...
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
After this operation, 26.1 MB disk space will be freed.
(Reading database ... 34533 files and directories currently installed.)
Removing postgresql-contrib-9.5 (9.5.5-1.pgdg16.04+1) ...
update-alternatives: warning: forcing reinstallation of alternative /usr/share/postgresql/9.5/man/man1/postmaster.1.gz because link group postmaster.1.gz is broken
update-alternatives: error: error creating symbolic link '/usr/share/man/man1/postmaster.1.gz.dpkg-tmp': No such file or directory
dpkg: error processing package postgresql-contrib-9.5 (--remove):
 subprocess installed pre-removal script returned error exit status 2
dpkg: postgresql-9.5: dependency problems, but removing anyway as you requested:
 postgresql-contrib-9.5 depends on postgresql-9.5 (= 9.5.5-1.pgdg16.04+1).
Removing postgresql-9.5 (9.5.5-1.pgdg16.04+1) ...
invoke-rc.d: could not determine current runlevel
invoke-rc.d: policy-rc.d denied execution of stop.
Removing postgresql-client-9.5 (9.5.5-1.pgdg16.04+1) ...
Processing triggers for postgresql-common (178.pgdg16.04+1) ...
Building PostgreSQL dictionaries from installed myspell/hunspell packages...
Removing obsolete dictionary files:
Errors were encountered while processing:
FAILED
Pups::ExecError: apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5 failed with return #<Process::Status: pid 16 exit 100>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params "apt-get remove -y postgresql-9.5 postgresql-client-9.5 postgresql-contrib-9.5"
f39c918850fc3105167df6ad93b20c0bdf4678553c6bad4059ebe44016e8d179
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
That’s odd. Tagging has been in Discourse as a core feature for a few versions now.
Make sure you add a git pull in there if you were on a very old version:
cd /var/discourse
git pull
I was on 1.6.x (the latest before 1.7 I believe).
I’ll try.
Nope:
root@forum:/var/discourse# git pull
Already up-to-date.
Should I enter the docker container and then try:
apt-get update
What is supposed to be going on with postgresql?
The error reports
But if I do apt-get update to see what it wants to do, it wants to install postgresql-9.3 postgresql-client-9.3 postgresql-contrib-9.3
So which version is supposed to be installed? Why would 9.5 be installed already and why would it want to remove it when upgrade wants to install 9.3?
We updated our docker image to Postgres 9.5 back in May 2016
https://meta.discourse.org/t/discourse-docker-image-version-1-3-3-released/44778
OK, my app.xml was still saying postgres 5.3. I changed it to just postgres and the rebuild worked and I am back up and running.
Thanks for your assistance!
Now I should be able to reenable the solved plugin.
I presumably don’t need to reenable the tags plugin as you say.
