Newrelic plugin
New Relic support
Author: Sam Saffron
Support for http://newrelic.com
plugins/newrelic/plugin.rb
# name: enable New Relic rpm
# about: New Relic support
# version: 0.1
# authors: Sam Saffron
ENV["NRCONFIG"] = File.expand_path('../newrelic.yml', __FILE__)
gem "newrelic_rpm", "3.6.7.152"
NewRelic::Control.instance.init_plugin :config => Rails.configuration
after_initialize do
  ForumsController.newrelic_ignore :only => [:status]
plugins/newrelic/newrelic.yml
The file you got from newrelic
TODO: move this to git
9 Mi Piace
For the documentation:
Installation
Copy this file into
Retrieve a copy of your newrelic.yml file:
https://rpm.newrelic.com/accounts/[123456]/newrelic.yml
Where you need to replace 123456 with the application number you see in your NewRelic interface.
Save this to config/newrelic.yml`
(unless there’s some reason to keep it at the root of the install, as shown above)
Otherwise I’d change that 6th line to:
../config/newrelic.yml
Activation
The Newrelic gem will be installed the next time bundler is called.
cd /var/www/discourse (or or where you’ve installed discourse)
bundle install --without test --deployment
(is that correct?)
Would I need to do anything else besides what’s outlined?
Is that bundle command needed?
New Relic is wicked. Thanks for the plugin!
2 Mi Piace
I took it upon myself to create a GitHub repository for this; it’s pretty much unchanged, but it does use the most up-to-date Ruby agent version while also providing a newrelic.yml file that will look for NEW_RELIC_LICENSE_KEY and NEW_RELIC_APP_NAME variables.
Bonus: installation instructions for the Docker image. Thanks for the initial version, @sam!
https://github.com/davidcelis/new_relic-discourse
8 Mi Piace
Nice!
@davidcelis would you mind if we added this to http://newrelic.com/connect/ ?
3 Mi Piace
Yep, we should do that.
@davidcelis
Is there anyway to use your github version without restarting and loosing the content of an initial app with a container?
You won’t lose the content, as both the PostgreSQL and Redis databases are stored in a folder that’s shared with the host. You will have to destroy the container and re-bootstrap it, but all your data (posts, users, topics, etc.) will still be there.
I wish there was a better way.
For anyone else looking to further integrate New Relic, they offer an availability monitoring service. This way you can get alerts if Discourse ever goes down. (Ideally, that would be never!)
Discourse already has an OK status URL that works wonderfully for this purpose. If you go to your Discourse application in New Relic, then Settings → Availability Monitoring, New Relic asks for a URL to monitor. You can use /srv/status from your application, like https://meta.discourse.org/srv/status and hit “Save”.
7 Mi Piace
@davidcelis @sam
Questo plugin non è più compatibile con Discourse. Ci sono altre soluzioni proposte per monitorare le prestazioni?
3 Mi Piace
Ciao, ci sono novità sulla nuova versione di questo plugin? Grazie.
