תכונת Srcset עשויה לטעון תמונות גדולות יותר במובייל מאשר בדסקטופ
סיכום מבוסס בינה מלאכותית
Srcset attribute may load larger images on mobile than desktop
The discussion revolves around the issue of loading large images on mobile devices, specifically in the context of the srcset attribute. jidanni initially raises the concern, citing a specific image that takes a long time to load on their cellphone screen due to its large size.
jidanni clarifies that the issue is not a bug, but rather a matter of bad User Experience, as the large image size can consume a significant amount of data. Stephen suggests that the issue may be related to the user’s ISP and peering, but jidanni counters that the image dimensions are larger than the entire cellphone screen.
The discussion takes a turn when Canapin discovers that the onebox loads a larger image on mobile (1380x920, 500 KB) compared to desktop (690x460, 160 KB). Arkshine explains that the srcset attribute serves images based on device pixel ratio, which can result in higher resolution images being loaded on mobile devices with higher pixel density.
Lilly and Canapin acknowledge that this behavior is not a bug, but rather a design choice based on device capability. jidanni reiterates their concern, suggesting that a smaller thumbnail size could be used without compromising the user experience.
The issue is eventually addressed with the merge of a PR that reduces the onebox thumbnail size for Wikimedia links blake. A more general fix for all oneboxes is also created, reducing the thumbnail size from around 400 KB to 100 KB blake.
Did anybody notice something funny as the above preview loaded onto your cellphone screen?
Why was the image taking so agonizingly long to finally fill in the entire preview square?
That’s because it’s a very large image!
So why does a very large image need to be gobbling up the user’s data plan, taking so long when an itsy bitsy preview would have shown up before you would have even noticed it?
No I’m not exactly sure who to blame.
No. It’s not a bug. The image gets there sooner or later. I’m just saying it’s bad User Experience. The user thinks nobody cares about his data plan, and the page doesn’t finish loading as fast as other pages.
2 לייקים
I didn’t really notice the loading time, which suggests it’s your browser or network.
First time from a different device:
That one was Chrome on iOS
2 לייקים
Not so fast. You, in your Ivory Tower in your first world country would never know the difference. But me in my non Ivory tower, in my non first world country, notice the difference very much!
Use Developer Tools, set Country to second or third world, :smile:, turn off the cache, and reload the page.
לייק 1
So your complaint is with your ISP and their peering?
To be clear the original image is 3.4mb, that thumbnail is served from Cloudfront, is 690x460 and weighs in at 164Kb.
Either way, what are you proposing? That cloudfront makes for a bad CDN for users in your region? That Discourse didn’t download and create the optimized images quickly enough?
3 לייקים
All I know is those dimensions are larger than the entire cell phone screen itself!
לייק 1
I have a small smartphone (4.6 inch | 720 x 1.280 pixel). My screen is not smaller that the thumbnail. How small is your screen?
לייק 1
In your non ivory tower country where data is 8x cheaper than in the USA and still 2.5 times cheaper than in Europe? (source) or do you mean in your non ivory tower country with the fastest broadband internet in the world (source) ? Or maybe you meant your non ivory tower country that for mobile data still ranks 28th, way above many first world countries? (source)
Sounds like you just need a bigger phone.
4 לייקים
Judging by previous posts Jidanni has a Galaxy A13 5G and a Zenfone 3:
Galaxy A13 5G: 6.5”, 1600 x 720
Asus Zenfone 3: 5.5”, 1920 x 1080
As the optimized thumbnail is 690x460, and it’s dimensions are further restricted by the onebox, it isn’t bigger than their screen. They do use browser scaling though, so who knows :man_shrugging:t2:
לייק 1
Something may be fishy here.
On desktop view, the onebox loads a 690x460px, 160 KB picture, whereas on mobile it loads a 1380x920, 500 KB picture. :thinking:
I move the topic to Contribute > Bug. It seems like a bug to me, maybe it will be recategorized later :slight_smile:
4 לייקים
I may be wrong, but I think it makes sense.
If you look at the HTML srcset, the following images are served based on the device pixel ratio (x1, x1,5, x2).
https://...2f50d4ad9f5f865b783b02d392de75bdceec01da_2_690x460.jpeg,
https://...2f50d4ad9f5f865b783b02d392de75bdceec01da_2_1035x690.jpeg 1.5x,
https://...2f50d4ad9f5f865b783b02d392de75bdceec01da_2_1380x920.jpeg 2x
Usually, mobile has an x2 ratio (or more) because they have a higher pixel density.
So you would want to serve images with higher resolution.
Device Pixel Ratio
Device Pixel Ratio(DPR) is a number given by device manufacturers and it’s used for HiDPI(High Dots Per Inch) or Retina(Apple’s trademark) displays, which are part of modern smartphones, tablets and even some laptops and monitors.
DPR is in direct correlation with pixel density of the display, the higher the density the greater the DPR value.
DPR is the ratio between physical(device) pixels and logical(CSS) pixels in either horizontal(width) or vertical(height) direction of a screen.
In other words, DPR is a number used for calculating CSS resolution of the screen. From DPR we can directly see how many actual physical hardware pixels make up one CSS pixel.
Example:
Apple iPhone 12
Resolution in device(physical) pixels: 1170 x 2532
DPR: 3
Width: 1170/3 = 390, Height: 2532/3 = 844
Therefore, resolution in CSS pixels: 390 x 844
Since DPR is 3, in pixel grid: 3(width) x 3(height) = 9; 9 physical pixels are used to form one CSS pixel.
5 לייקים
yea i don’t believe this is a bug. my ipad on mobile view loads higher res photos than my desktop because it can. i could be wrong, but it was my understanding that it’s dependent on device capability, not screen size.
also, i’m still not clear on whether this topic is about the one box thumbnail itself or the actual photo loading when you click the one box link?
2 לייקים
Good catch.
You likely won’t notice a lower resolution image on smartphones due to their screen size, and I think, in general, they are more likely to have a slower Internet connexion via the mobile network than a home Internet connexion. In this regard, I wouldn’t expect a mobile experience to load a larger image than on a desktop computer.
But scrset dictates which image to load for which pixel ratio. :confused:
It’s definitely not a bug, I’ll move it back to Contribute > UX :person_shrugging:
2 לייקים
The thumbnail.
Indeed here we see in the Kiwi browser the Developer Tools results,
Yes, we’re talking at 500 kilobyte thumbnail.
What would Tim Berners-Lee think?
Okay, I did a web search and indeed it’s a reasonable size for a thumbnail – if you are uploading it to YouTube.
I mean it must be a pretty fantastic hologram 50 dimensional thumbnail or something. Are you sure you couldn’t do the same one about 5000 bytes? Would the user be able to detect any difference? No I’m not blaming anybody for the energy crisis or slowing down the web. I just think with the destination being a small cellphone something could be done better.
I mean there has to be some point where just adding more bytes, no matter what cellphone sized device they have, won’t make any difference for human beings unless they have eagle eyes but they’re not eagles they’re humans.
2 לייקים
I agree something is off here for sure … that image is way too big. Our onebox implementation is asking for a supersized image when a much smaller one would do.
We will have a look over the next month or so.
7 לייקים
This PR has just been merged that addresses the onebox thumbnail size issue specifically for Wikimedia links.
https://github.com/discourse/discourse/pull/22620
And here is a Wikimedia link to test it out:
A more general fix applicable to all onebox thumbnail sizes will still need to be developed.
4 לייקים
A more general fix for all oneboxes has been created:
https://github.com/discourse/discourse/pull/22621
For testing I used articles from this non-wikimedia site: Read the latest Great Reads stories from car lovers like you - Hagerty Media as they had fairly large images to onebox.
Before:
After:
Before this change onebox images were around 400kb. After my change they are around 100kb.
Here is a onebox example which is using the reduced thumbnail size
https://www.hagerty.com/media/car-profiles/driving-the-prodrive-p25-brought-out-my-inner-car-crazy-kid/
4 לייקים
This topic was automatically closed after 41 hours. New replies are no longer allowed.
