Problema SSL con proxy SSL
Good day!
I have installed NGINX Reverse Proxy before Discourse, where certificates are managed, so the user connects to Discourse via a secure HTTPS connection.
However, some template files, such as icons, are downloaded over HTTP, which causes Firefox to report an insecure connection. These files are:
<link rel="apple-touch-icon" type="image/png" href="http://
<link rel="search" type="application/opensearchdescription+xml"
<meta name="twitter:image"
and other.
If I enable the “Force HTTPs” mode in the settings, this problem disappears, but there is another - I can neither create categories, nor create new topics, nor even log in - the forum gives the 403rd error.
Version 2.3.0 is currently installed.beta 8 +123.
Thank you in advance
There is a site setting called
  force https
Enable it.
E-Mail confirmation also don’t work when force https enabled.
Here is solution, maybe it will help for someone:
Just add
proxy_set_header X-Forwarded-Proto https;
to NGINX proxy config.
Thnx a lot!
This is covered in many, many topics here…
