כניסת SSO נראית הפסיקה לעבוד
סיכום מבוסס בינה מלאכותית
Issue with SSO Login
The discussion revolves around an issue with Single Sign-On (SSO) login, where users are redirected to the login page after attempting to log in through SSO.
jeffbonasso reports that users are experiencing this issue, despite the user account being created in Discourse. He shares his AWS Lambda function and code, which uses the latest discourse-sso JavaScript library.
david suggests that the issue is caused by a bug in Chrome 97, which has been fixed in the latest version of Discourse. However, jeffbonasso mentions that he is using a hosting provider and cannot upgrade to the latest version.
RJG from the hosting provider offers to look into the issue and suggests creating a ticket. david shares the commit that contains the fix.
However, RGJ notes that the fix is already present on jeffbonasso’s forum, and the issue persists. jeffbonasso reports that the issue is only present in Chrome and Brave browsers, but not in Safari or Edge.
sam suggests that the bypass is Chrome-specific and may need to be extended to other browsers. Falco notes that the fix is already included in the latest Chrome version and should be rolled out to Chrome derivatives soon.
david clarifies that the DiscourseConnect fix was applied across all browsers, and the global fix was specific to Chrome.
I have had SSO integration from my site for a few years now with no issue.
Recently users started saying that when they login it redirects to my site to login and then ends back up at Discourse still showing they need to Login. I having been trying to debug but I am not seeing any issues. It just seems like at the end when it does the redirect to Login something is going wrong.
When I look in Discourse the user account is created, but for some reason it is not logging them in.
Here is a quick video showing what I am seeing…
I followed this info:
…and am using the latest discourse-sso javascript library.
This is my AWS Lambda which is fronted by an API Gateway…
'use strict';
exports.handler = (event, context, callback) => {
    console.log(event);
    var discourse_sso = require('discourse-sso');
    var sso = new discourse_sso("********************"); // secret hidden
    var body = JSON.parse(event.body);
    var payload = body.sso; // fetch from incoming request
    var sig = body.sig; // fetch from incoming request
    if(sso.validate(payload, sig)) {
        var nonce = sso.getNonce(payload);
        var userparams = {
            // Required, will throw exception otherwise
            "nonce": nonce,
            "external_id": body.externalId,
            "email": body.email,
            // Optional
            "username": body.username,
            "name": body.name
        console.log("User: " + JSON.stringify(userparams));
        var q = sso.buildLoginString(userparams);
        console.log("q: " + q);
        // Redirect
        var response = {
            statusCode: 200,
            headers: {
                "Access-Control-Allow-Origin": "*"
            body: JSON.stringify({"q":q})
        callback(null, response);
    } else {
        // What to do if doesn't validate?
        var responseError = {
            statusCode: 200,
            headers: {
            body: JSON.stringify({"error":"SSO Validation Error"})
        callback(null, responseError);
When the Login button is clicked from Discourse it calls my web app where the user is validated and then if validation passes calls the following…
						if (state.get(["appState", "urlParams", "sso"]) && state.get(["appState", "urlParams", "sig"])) {
							var userMetadata = getUserMetadata(result);
							var body = {
								sso: state.get(["appState", "urlParams", "sso"]),
								sig: state.get(["appState", "urlParams", "sig"]),
								externalId: keyPrefix,
								email: userMetadata.email,
								username: username
							request
								.post('https://**********.execute-api.us-east-1.amazonaws.com/prod/discourse-sso')
								.send(body)
								.end(function (err, res) {
									if (err || !res.ok) {
										alert(err.message);
									} else {
window.location.replace("https://forum.miralouaero.com/session/sso_login?" + res.body.q);
Any help understanding what may be going on would be appreciated.
This is most likely caused by a bug in Chrome 97, which was released this month. While we wait for Google to roll out a fix, we’ve added a workaround to Discourse. Upgrading your site to the latest version should solve the problem.
3 לייקים
Unfortunately I am using a hosting provider. Any other workarounds? If I turn off SSO off for the time being from Discourse and then turn back on when fixed will that wreak any havoc? I assume users would have to manually create an account in that case. When I re-enable just curious if then will create a new account associated with my system.
I’m afraid not. Our managed discourse.org hosting is up-to-date. Can you share which provider you’re using? We might be able to get in touch and let them know about the update.
If email addresses match up, then it should work seamlessly. Initially, users will need to use the “forgot password” button to create a password
לייק 1
@jeffbonasso I see you’re hosted with us, we’re going to look for a solution for you. Can you please create a ticket using our control panel, referring to this topic?
No, that would work. If you turn it back on then the SSO will recognize the email address.
But existing users might have a hard time logging on, since they don’t have a password for the forum directly.
@david May I ask - which Discourse commit contains that fix?
לייק 1
For the stable branch, this is the fix:
https://github.com/discourse/discourse/commit/909de9b36c86d98793127fadc54bc3e656949c1e
There is a similar commit on beta and tests-passed as well
2 לייקים
Thank you David,
That fix is already present on your forum since January 13 @jeffbonasso , so this cannot be it (or the reports you got are from before that date?)
לייק 1
The video I created was with a test user I created this morning and the behavior was consistent with what a customer was experiencing. Interesting, I just tried logging in with Safari and it worked. I then tried Chrome again and that is also now working. The Chrome version I just tested with is Version 97.0.4692.99 (Official Build) (x86_64). I am going to reach out to a customer who was having issues to see if they are still having issues.
2 לייקים
FYI…the customer reported they are using the Brave browser, a Chrome derivative. He said it is still not working, He then tried Edge and it is working.
our bypass is chrome specific, we may need to extend the net here @Falco / @david
I wonder if we should add a site setting to disable service workers that people can flick on if they experience issues like this?
It’s already fixed in the latest Chrome version since 2022-01-19T03:00:00Z so I believe the Chrome derivatives will follow shortly as the release with this fix, 97.0.4692.99, also includes one critical and 15 high security fixes.
2 לייקים
We applied the DiscourseConnect fix across all browsers. The later global fix was specific to Chrome, but it should also target Edge/Brave thanks to their user agent strings:
Edge: 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/97.0.4692.71 Safari/537.36 Edg/97.0.1072.55'
And Brave apparently doesn’t customize the default chrome user agent
3 לייקים
