SSO gestopt met werken, SSO uitgeschakeld, nu word ik geblokkeerd op IP
TheKingEagle is unable to log in to their admin account after disabling SSO, facing an IP block despite enabling local logins. They cannot access the admin panel to check their IP whitelist. pfaffman suggests using a different IP, such as via mobile data, and mentions the /u/admin-login bypass. TheKingEagle tries logging in from their phone, successfully accesses the admin panel, and whitelists the server IP. They discover the reverse proxy is misconfigured, causing all traffic to appear from the server IP, which explains both the IP block and the SSO failure. After resolving the issue, they regain access and confirm SSO is working again TheKingEagle.
Hello! I am completely unable to login to my admin account on my site, to attempt to diagnose why SSO suddenly decided to stop working. I disabled SSO from the console, and enabled local logins. Now I am still unable to login because I “Can’t login from this IP”. I cant access the admin panel to see if my IP is listed. I took advice from another post to try to find it from the console, but it is not there either. Any advice to restore my access to my account?
I even went as far as to create a new admin account from the console, but same problem. I cant access it from my IP (which hasn’t changed since 2017)
Can you use a mobile phone network to get another ip? Or coffee shop or friend’s house?
Those look like some easy suggestions.
Also /u/admin-login will let you bypass sso (though it’s apparently too late for that to be useful).
Also, if you have a reverse proxy misconfigured then all users might appear to come from the reverse proxy.
I’ve tried logging in from my phone (still had a valid session thankfully). I can see the admin now. I just whitelisted the server IP… The reverse proxy is indeed misconfigured as I appear to be coming from the server ip. could this also explain why SSO stopped working?
Alright, that was(is) indeed the problem. I have access again, and SSO is working again. I will have to look into the reverse proxy config later. Thank you for assisting!
