I’m trying to set up a new installation of Discourse using the stable branch. The installation completes successfully if I leave app.yml set to “tests-passed”. However, if I change that to stable and rebuild, it fails with:
I, [2018-01-01T11:55:35.349654 #13] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
URGENT: type Failed to initialize site default
rake aborted!
ArgumentError: type
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:46:in `eval'
/var/www/discourse/lib/site_setting_extension.rb:221:in `block (2 levels) in refresh!'
/var/www/discourse/lib/site_setting_extension.rb:220:in `map'
/var/www/discourse/lib/site_setting_extension.rb:220:in `block in refresh!'
/var/www/discourse/lib/site_setting_extension.rb:216:in `synchronize'
/var/www/discourse/lib/site_setting_extension.rb:216:in `refresh!'
(eval):6:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:46:in `block (2 levels) in run_file'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:58:in `block in open'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:57:in `open'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:36:in `block in run_file'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `block in transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/connection_adapters/abstract/transaction.rb:184:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/connection_adapters/abstract/database_statements.rb:213:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/activerecord-4.2.8/lib/active_record/transactions.rb:220:in `transaction'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:35:in `run_file'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:26:in `block in run'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:25:in `each'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu/runner.rb:25:in `run'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/seed-fu-2.3.5/lib/seed-fu.rb:29:in `seed'
/var/www/discourse/lib/tasks/db.rake:8:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.4.0/gems/rake-11.3.0/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Tasks: TOP => db:migrate
I, [2018-01-01T11:55:39.870156 #13] INFO -- :
== Seed from /var/www/discourse/db/fixtures/001_categories.rb
I, [2018-01-01T11:55:39.870684 #13] INFO -- : Terminating async processes
I, [2018-01-01T11:55:39.870854 #13] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/9.5/bin/postmaster -D /etc/postgresql/9.5/main pid: 44
2018-01-01 11:55:39.871 UTC [44] LOG: received fast shutdown request
2018-01-01 11:55:39.871 UTC [44] LOG: aborting any active transactions
2018-01-01 11:55:39.871 UTC [51] LOG: autovacuum launcher shutting down
I, [2018-01-01T11:55:39.871055 #13] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 159
159:signal-handler (1514807739) Received SIGTERM scheduling shutdown...
2018-01-01 11:55:39.874 UTC [48] LOG: shutting down
2018-01-01 11:55:39.890 UTC [48] LOG: database system is shut down
159:M 01 Jan 11:55:39.894 # User requested shutdown...
159:M 01 Jan 11:55:39.894 * Saving the final RDB snapshot before exiting.
159:M 01 Jan 11:55:39.903 * DB saved on disk
159:M 01 Jan 11:55:39.903 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 1508 exit 1>
Location of failure: /pups/lib/pups/exec_command.rb:108:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"bundle_exec", "cmd"=>["su discourse -c 'bundle install --deployment --verbose --without test --without development --retry 3 --jobs 4'", "su discourse -c 'bundle exec rake db:migrate'", "su discourse -c 'bundle exec rake assets:precompile'"]}
d6f04ca979800ae6938c231f5ec57316431b6cbbe358bd1c843fcc1f94db984a
** FAILED TO BOOTSTRAP ** please scroll up and look for earlier error messages, there may be more than one
I have tried rebuilding multiple times and I’ve tried completely destroying the installation and starting again but it always fails this way. Changing the branch back to tests-passed allows the rebuild to complete.
