Stackpath (Formerly MaxCDN) - Invalid or Unexpected Token
dfriestedt is experiencing issues implementing the Stackpath CDN (formerly MaxCDN) on their site, discuss.360velo.com. Initially, they added DISCOURSE_CDN_URL: https://b7f7x2b6.stackpathcdn.com but encountered an “Invalid or Unexpected Token” error. After removing a trailing slash from the URL, they still encountered errors. supermathie investigated and discovered that the CDN was stripping the Content-Encoding: br header, which is necessary for brotli compression. supermathie advised dfriestedt to change their CDN configuration to not strip this header. After submitting a support ticket to StackPath, dfriestedt reported that brotli compression was enabled, and the site is now working as expected.
I’m trying to implement the Stackpath CDN (formerly MaxCDN)
The site is discuss.360velo.com. I’ve followed the CDN instructions.
I added
DISCOURSE_CDN_URL: https://b7f7x2b6.stackpathcdn.com and rebuilt the app.
The site does not load properly. Upon inspection, I’m getting an Uncaught Syntax Error: … Missing / and I get Invalid or Unexpected Token
Then I tried
DISCOURSE_CDN_URL: https://b7f7x2b6.stackpathcdn.com/ (I added the / at the end) and rebuilt the app.
Now I get the following error.
Refused to load the script 'https://b7f7x2b6.stackpathcdn.com/assets/browser-update-d924ff41586d6dcda055f0cfb41488724ba2e2d5271fef65ce5f480b46f9231d.js' because it violates the following Content Security Policy directive: "script-src 'unsafe-eval' 'report-sample' http://discuss.360velo.com/logs/ http://discuss.360velo.com/sidekiq/ http://discuss.360velo.com/mini-profiler-resources/ https://b7f7x2b6.stackpathcdn.com//assets/ https://b7f7x2b6.stackpathcdn.com//brotli_asset/ http://discuss.360velo.com/extra-locales/ https://b7f7x2b6.stackpathcdn.com//highlight-js/ https://b7f7x2b6.stackpathcdn.com//javascripts/ https://b7f7x2b6.stackpathcdn.com//plugins/ https://b7f7x2b6.stackpathcdn.com//theme-javascripts/ https://b7f7x2b6.stackpathcdn.com//svg-sprite/". Note that 'script-src-elem' was not explicitly set, so 'script-src' is used as a fallback.
What am I missing?
DISCOURSE_CDN_URL should not have a slash at the end. Can you go back to your first attempt and then we can investigate the place from where that error is coming?
(true, Discourse should handle the CDN URL whether a slash was appended or not)
OK - thanks for looking into this.
I’ve changed back to
without the trailing slash.
here is the new error message
Uncaught SyntaxError: Invalid regular expression: missing /
Uncaught SyntaxError: Invalid or unexpected token
OK, that’s better.
If we click on one of those we get binary data that indicates the browser doesn’t understand how to decode what’s being sent back:
If we look at the actual response headers from the CDN:
○ → curl -I https://b7f7x2b6.stackpathcdn.com/brotli_asset/locales/en-7198f510be5ac202c75f0bb40bbaa99b06947b8590d6ed10bb353c4108efc819.js
HTTP/1.1 200 OK
Date: Thu, 14 Mar 2019 15:49:54 GMT
Accept-Ranges: bytes
ETag: "1552576873"
Content-Type: application/javascript
Last-Modified: Thu, 14 Mar 2019 15:21:13 GMT
Access-Control-Allow-Origin: *
Server: nginx
X-Frame-Options: SAMEORIGIN
X-XSS-Protection: 1; mode=block
X-Content-Type-Options: nosniff
X-Download-Options: noopen
X-Permitted-Cross-Domain-Policies: none
Referrer-Policy: strict-origin-when-cross-origin
X-Discourse-Route: static/brotli_asset
Content-Transfer-Encoding: binary
Cache-Control: max-age=31556952, public, immutable
X-Request-Id: 08fe3ea9-569b-4eb8-9dc0-3a60ad2f13f3
X-Runtime: 0.009359
Strict-Transport-Security: max-age=31536000
X-HW: 1552578594.cds008.tr2.hn,1552578594.cds002.tr2.c
Connection: keep-alive
Content-Length: 66601
and compare it with the non-CDN response:
○ → curl -I https://discuss.360velo.com/brotli_asset/locales/en-7198f510be5ac202c75f0bb40bbaa99b06947b8590d6ed10bb353c4108efc819.js
HTTP/1.1 200 OK
Server: nginx
Date: Thu, 14 Mar 2019 15:52:11 GMT
Expires: Sat, 14 Mar 2020 15:52:11 GMT
X-Request-Id: 5b139520-2d13-4eb0-83ef-cafc83ba656f
X-Runtime: 0.003118
You’ll note that the CDN has stripped the important header: Content-Encoding: br that tells the browser “this response is brotli-encoded”. So it can’t interpret it properly.
You’ll need to change your CDN configuration to not strip this header.
awesome. let me work on that and report back.
Thanks for the help. I had to submit a support ticket with StackPath and they enabled brotli compression. The site is working as expected.
thx
