Help with white screen when using any cdn
hi, I have added my site to stackpath and added the ‘edge address’ to app.yml and rebuilt, now all of my static files direct to stackpath as expected. However when i go to my domain now I only see a white screen. i thought this might be a stackpath issue so I also tried these steps with bunnycdn (which has worked fine previously) and still I now only see a white screen.
my stackpath edge address however xxxxxx.stackpathcdn.com loads my site completely fine
does anyone know what this issue this? thanks
update: i checked console which is full of ‘invalid character’ messages, when i open the corresponding js files it is full of: ‘¾ØýÈOÝ´þäùKe˜žXÞ¬¬½õ’
also when i change the ‘host header’ to ‘dynamic’ the site will load at the original domain however this causes all the static files to redirect which causes big delays.
It’s the weekend so you may need to be patient for better help. But it looks like the problem involves mis-matched character encoding. I tend to have everything in UTF-8 — browsers, text editors, meta tags, database collation, etc. everthing
What language(s) / character encoding(s) are you working with?
Glaswegian. (That’ll be it, likely.)
Not entirely sure i understand but i haven’t changed any of the default discourse settings in that regard..
This sounds like you’re getting compressed assets but the browser is treating them as uncompressed and trying to interpret directly.
